ARRL Files Federal Appeals Court Brief in Petition for Review of BPL Rules:
from The ARRL Letter, Vol 26, No 21 on May 25, 2007
The ARRL has filed a federal appeals court brief outlining its case and requesting oral arguments in its petition for review of the FCC's broadband over power line (BPL) rules. The League has petitioned the US Court of Appeals for the DC Circuit to review the FCC's October 2004 Report and Order (R&O) in ET Docket 04-37 and its 2006 Memorandum Opinion and Order. In its brief filed May 17, the ARRL contends, among other things, that the FCC's actions in adopting rules to govern unlicensed BPL systems fundamentally alter the longstanding rights of radio spectrum licensees, including Amateur Radio operators.
"For the first time ever, the FCC has permitted new unlicensed devices to operate in spectrum bands already occupied by licensees, even if the unlicensed operations cause harmful interference to the licensees," the League said in stating its case. "The orders under review reverse nearly seven decades of consistent statutory interpretation and upset the settled expectations of licensees without so much as acknowledging the reversal, let alone justifying it."
The ARRL argues that the FCC's approach to adopting rules to govern BPL flies in the face of Section 301 of the Communications Act, which requires that operators of devices that emit radio frequency energy first obtain an FCC license. "For years, the FCC has consistently read Section 301 to apply to unintentional radiators, such as BPL devices, and has expressly embodied that interpretation in its rules," the League's brief recounts.
The Commission then compounded its error by asserting that BPL devices do not fall within Section 301 at all, the League said. "This hail-Mary attempt at justification is another unexplained departure from prior policy that independently requires invalidation of the orders," the ARRL remarked in its brief.
The ARRL contends that the FCC orders under review "jeopardize the license rights of ARRL's members and other license holders by authorizing providers of a new device -- Access Broadband over Power Lines, or 'BPL' -- to send radio signals across the electric grid in the frequencies the license holders occupy, but without having to obtain an FCC license."
The League's brief further asserts that the FCC "has failed to discuss or disclose significant information in the record that potentially contradicts its key interference findings," and seeks to have the FCC produce the information. The ARRL alleges that the Commission not only withheld its internal studies until it was too late to comment but has yet to release portions of studies that may not support its own conclusions. The FCC has claimed that these are "internal communications" that it did not rely upon in reaching its decision to adopt the BPL rules.
"If, as seems more likely, the Commission actually considered and rejected the information contained in the redacted portions of its studies, then it had a duty to disclose the information and reasons for rejecting it. Either way, the FCC acted improperly."
The League also takes issue with what it argues is the FCC's "arbitrary and capricious" adoption of a BPL emission measurement standard that's unsupported by the record in the proceeding and ignores contrary evidence. Additionally, the ARRL says, the FCC rejected a proposed alternative without even considering it.
Said ARRL CEO David Sumner, K1ZZ, in his "It Seems to Us . . ." editorial for July QST: "The Commission's penchant for ignoring contrary evidence is illustrated even more vividly with regard to how quickly RF emissions are assumed to decay as one moves away from the source. This is important because if the signal is assumed to decay more quickly than it really does, the interference potential of the emissions will be underestimated."
As Sumner notes, the FCC has claimed that "many parties" have presented experimental data supporting a 40 dB per decade (10 times increase in distance) rate. "In fact, there is no such evidence in the record -- and empirical evidence supporting a lower number was ignored," he asserts.
The League maintains that the Commission failed to consider the ARRL's sliding-scale alternative that would have avoided what Sumner calls "the logically indefensible situation that now exists in the rules: the extrapolation factor is 20 dB/decade at 30.001 MHz and 40 dB/decade at 29.999 MHz."
In addition, the ARRL wants the court to determine if the FCC was arbitrary and capricious in failing to limit BPL providers "to frequencies where interference was less likely to occur without materially harming BPL deployment." The League argues that the FCC ignored evidence that restricting BPL to the 30-50 MHz frequency range would have obviated interference to long-distance HF communications without causing problems for public safety services.
The ARRL brief asserts that, for the first time ever, the FCC "has authorized the operation of unlicensed devices that it concedes interfere with licensed devices" and has declared that such devices "may continue operating even where proven to cause interference."
The FCC, ARRL contends, has concluded that BPL's acknowledged interference risks are manageable, but it bases that conclusion -- which ARRL calls "the linchpin of the challenged orders" -- on FCC studies the Commission has declined to make public in unedited form.
"It is clear," the ARRL contends in his brief, "that the withheld pages contain information" that is at odds with the FCC's conclusion to adopt the current rules governing BPL deployments.
"ARRL is not trying to stop the deployment of BPL," the League's brief concludes. ARRL and other commenters have provided the FCC with alternative proposals -- ones that have been demonstrated to work in the real world -- that would have allowed BPL to prosper without harm to licenses or to Congress's licensing regime."
"What is perhaps most unfortunate about the FCC's radical actions in this case is that they were entirely unnecessary."
The FCC's response to the League's brief is due July 2.
The ARRL Letter Vol. 26, No. 21 May 25, 2007
The Parade of ARRL bashers - let it begin!
by AI2IA on May 25, 2007 Mail this to a friend!
"The FCC's response to the League's brief is due July 2."
Okay for now, all you ARRL bashers. Are you intelligent enough to hold your diatribes until the FCC response appears? Of course not! Now will begin the long thread of nonsense from the eHam club of misfits and malcontents, and the words of so-called wisdom of a couple of BPL fans. Can you tell us what to expect from the FCC? Aw, go on! Go out on a limb and tell us what the FCC is going to say. You know it all. All you have to do is put it in words that are sure to humble the rest of us. Right? Pah!
RE: The Parade of ARRL bashers - let it begin!
by URBANGORILLA on May 25, 2007 Mail this to a friend!
Yep. Sure. The ARRL has the FCC by the cojones. Right. Ray, you are suffering from dementia. Its time you checked into a nursing home, dude. :)
UG
by W2RDD on May 26, 2007 Mail this to a friend!
If I were heavy into the manufacturing companies' stock, or involved in producing the technology, I might be self-serving enough to support BPL.
But I'm not and I don't.
The FCC comments will be most interesting.
by NN4RH on May 26, 2007 Mail this to a friend!
Sure, since you asked so nicely.
In my opinion, the FCC already have said everything they should say or need to say, it's all on record, and they've been very consistent and logical about it. So I would expect them to say the same things again.
They might add one point:
When was the last time we've seen a NEW BPL complaint hilited on the ARRL website? When was the last unresolved case of interference to a fixed/home station reported on the ARRL news? All we keep hearing about is these one or two year old cases of a couple of mobile operators in Manassas.
So wouldn't you agree that if the worst case against the FCC, is a couple of guys that a year or two ago deliberately sought out BPL noise, and found it; that actually could be used as an argument that the FCC rules are working quite well.
So, my guess is that maybe they'll add that to their response.
I'd be far more interested in what the ARRL brief actually says - i.e. not what this highly-spun self-serving news article says - but the actual filed court brief itself.
You need to switch to de-caf.
I've noticed that you are almost always the very first one to post replies to this Articles on certain subjects. Do you sit at your computer 24x7 checking eHam continuously? Do you ever find time to actually use a radio?
by KG6AMW on May 26, 2007 Mail this to a friend!
More than anything else I would like to see the FCC's technical data that lead them to their decision to approve BPL.
by K1CJS on May 26, 2007 Mail this to a friend!
This battle isn't over, not by a long shot. One thing that is interesting is that the ARRL is the leader of 99 percent of the fight against BPL, other groups and agencies sign on as "co-sponsors", but the ARRL is doing almost all the actual work.
It is also interesting to note that a lot of the people that stand up here on this site and shout about the dire effects of BPL and how it may impact our hobby are always the first ones out there bashing the ARRL. Go figure.
AI2IA says, address the subject, not the poster.
by AI2IA on May 26, 2007 Mail this to a friend!
"I've noticed that you are almost always the very first one to post replies to this Articles on certain subjects. Do you sit at your computer 24x7 checking eHam continuously? Do you ever find time to actually use a radio?"
Mainly to NN4RH: If you see a pattern in the timing of some of my posts, Ronald, your barking up the wrong tree. I check eHam.net from time to time, and sometimes I'm the first to post. Whether you're first or whether you're last, Ronald, doesn't matter. What matters is what you say and how you say it. As for my air time, Ronald, don't guess, check my bio on QRZ.com, if that is so important to you. Want to try some other way to smear me? You do better by addressing the statement, if you can, and not the man. The argument to the man is an age-old fallacy.
RE: AI2IA says, address the subject, not the poste
by W6EM on May 27, 2007 Mail this to a friend!
NN4RH said: "I've noticed that you are almost always the very first one to post replies to this Articles on certain subjects. Do you sit at your computer 24x7 checking eHam continuously?"
Ron, you really have blinders on. Ray doesn't fit your mold nearly so much as your good bud ex-N1IR-now-W1YW does.
The last two on BPL are the only in the last 50 or so that IR/YW macalllit hasn't been first. Perhaps he's lost interest in Part 15 defenses.
by W1YW on May 27, 2007 Mail this to a friend!
Could that possibly be because they are the only ones remaining--- who even have a remote interest?
This initiative has no demonstrable support of the majority of the ARRL membership, let alone Part 97 licensees.
And Motorola has dropped it's 'ham friendly' BPL initiative, presumably because it solves a problem that is not deemed defining in making money in BPL.
Again, BPL is one of many non-ham telecom/wireless technologies. At worst we should be technology agnostic to BPL. At best we should ask: what is BPL and why should we care?
RE: The Chief BPL Defender Appears!!
by W6EM on May 28, 2007 Mail this to a friend!
Perhaps, now that BPL appears to be 'dead on the vine', we activists should target other obnoxious Part 15 sources.
by K4RAF on May 28, 2007 Mail this to a friend!
"we activists should target other obnoxious Part 15 sources"
Like what?
Part 15 on bands no one uses except a handful of guys a couple of weekends a year for contests?
The FCC has forced sharing upon us to make room for new technologies such as my personal favorite, wireless broadband...
You "activists" need to get off your whining duffs & do something instead of complaining about EVERYTHING.
K4RAF
Whats a matter, RAF, you got your pockets stuffed with Part 15 green too?
by K4JF on May 28, 2007 Mail this to a friend!
"Part 15 on bands no one uses except a handful of guys a couple of weekends a year for contests?"
There are no Amateur bands that fit that definition.
RAF: "You "activists" need to get off your whining duffs & do something instead of complaining about EVERYTHING."
Bragging's not my style, RAF.
I didn't see your name/call sign in any of the thousands of FCC comments.
Do tell us what you've done (besides what you accuse us of).
Lee
W6EM/4
by K4RAF on May 29, 2007 Mail this to a friend!
That answer is very simple Lee, I have changed with the times, unlike people such as yourself.
Adapting to an ever-changing world is survival. Crying about every perceived threat seals the doomed fate of the complainer.
Being an RF Engineer by trade, as well as holding 2 FCC licenses, means I work in & with radio.
K4RAF
by KE4MOB on May 29, 2007 Mail this to a friend!
You know, I probably was one of the more "vocal" anti-BPL hams around. I wrote an article here on eHam about it, which was reproduced several times by various organizations in their efforts to raise awarness. I commented to the FCC when the NPRM came out and filed a Petition For Reconsideration as well.
But looking back, I think my perspective has changed drastically. Perhaps I am jaded. Perhaps I have become more of a realist. Perhaps I don't buy into the fear or hysteria infused into every so called "news story" anymore. Most definitely my attitude toward ham radio has changed.
The simple facts are that ham radio does not possess the numbers, the skill level or the relevance in today's world to be a priority over delivery of a communications service to the masses.
I know, it's hard for many to accept. But it's true. Look around. Look at who we are. Look at where we've been, the changes that have been made, and the status quo with respect to the average amateur and the technology we use.
About 1 in every 465 US citizens has a ham license. And most of those are inactive. Active ham licensees probably account for no more than 1 in every 600 or 700 citizens, in my estimates.
Are we really that important? Are we really worthy of the resource the FCC has granted us?
From where I sit, the answer is no.
RE: arrl NOT likely to prevail.
by W9WHE-II on May 29, 2007 Mail this to a friend!
"......ARRL wants the court to determine [whether] FCC was "arbitrary and capricious" in failing to limit BPL providers "to frequencies where interference was less likely to occur without materially harming BPL deployment."
Proving that FCC's decision was "arbitrary and capricious", in light of ALL the evidence (including that favorable to BPL) will be a VERY tall order. Especially given the strong presumptions given to well established Federal agencies like FCC, its a presumption arrl is UNLIKELY to overcome.
I would NOT be betting against FCC on this one.
But heck, if we can't deny welfare to ILLEGAL AILENS and are required to provide a BI LINGUAL education to ILLEGAL AILENS....who knows!
RE: ARRL Files Federal Appeals Court Brief in Peti
by STRAIGHTKEY on May 29, 2007 Mail this to a friend!
"At best we should ask: what is BPL and why should we care?"
If you're still asking these questions, you probably shouldn't be commenting on bpl.
"If you're still asking these questions, you probably shouldn't be commenting on bpl."
Moreso, if you don't have a call you are willing to give, you really shouldn't be commenting on anything...
by W6EM on May 29, 2007 Mail this to a friend!
WHE-II said: "I would NOT be betting against FCC on this one"
Moreover, we shouldn't be betting against elements of a facist, corporatist government. It just doesn't pay. In fact, it costs......
by KC9JUB on May 30, 2007 Mail this to a friend!
Some of us seem to have more than enough trouble with English.
W9WHE-II:
<<But heck, if we can't deny welfare to ILLEGAL AILENS and are required to provide a BI LINGUAL education to ILLEGAL AILENS....who knows!>>
Bob - KC9JUB
by K1CJS on May 30, 2007 Mail this to a friend!
".......but the ARRL is doing almost all the actual work."
By W1YW:
"Could that possibly be because they are the only ones remaining--- who even have a remote interest?"
--No, they aren't. The NAB and public service agencies also have an interest and have said so.
"This initiative has no demonstrable support of the majority of the ARRL membership, let alone Part 97 licensees."
--It doesn't? You mean it has no support of the ARRL bashers on this site--the ARRL members that do support it probably wouldn't waste time telling us on this site that they do.
"And Motorola has dropped it's 'ham friendly' BPL initiative, presumably because it solves a problem that is not deemed defining in making money in BPL."
--That is because Motorola has switched its major BPL focus to areas of the bands that have no widely used ham bands to contend with.
"Again, BPL is one of many non-ham telecom/wireless technologies. At worst we should be technology agnostic to BPL. At best we should ask: what is BPL and why should we care?"
--If it would interfere with established services, whether those services are ham, public service, broadcast bands, or other services, we should care. Just one example: If your home was burning down and the fire department units weren't alerted to the fire because of BPL interference, I think you'd care.
We all should care if BPL interference causes problems with communications essential to daily living. Only an idiot would not.
by STRAIGHTKEY on May 30, 2007 Mail this to a friend!
"Moreso, if you don't have a call you are willing to give, you really shouldn't be commenting on anything... "
This site allows comments from "anonymous" logins so your repeated attempts to mute me are a waste of time.
I have to echo W6EM's question: what have you done? You whine about so-called complainers, yet all you do is complain about the lack of wifi use in ham radio and how ham radio is so screwed up. You seem to be one of the angriest and discontented hams on this site who does little to nothing to create the change you claim we so dearly need.
by W9WHE-II on May 31, 2007 Mail this to a friend!
W6EM writes:
"Moreover, we shouldn't be betting against elements of a facist, corporatist government".
Like Iran, Syria, and North Korea?
Lee, does that mean that you are BETTING ON the likes of Amidinijaad, Assaid & Kim Jong?
RE: But they are emcomm hams....damit!
KE4MOB writes:
"About 1 in every 465 US citizens has a ham license. And most of those are inactive. Active ham licensees probably account for no more than 1 in every 600 or 700 citizens, in my estimates"
BUT THEY ARE EMCOMM HAMS....DAMIT!
Emcomm super-heros should be given priority over the ENTIRE spectrum, because emcomm super-heros can save the world with no more then an HT, a revolving blue dash light and the contents of a "go kit".
Sheesh. Some people just don't get it.
by W6EM on May 31, 2007 Mail this to a friend!
I wrote: Moreover, we shouldn't be betting against elements of a facist, corporatist government.
Jonathan (who never gives his name)W9WHE-II responds:
"Like Iran, Syria, and North Korea? Lee, does that mean that you are BETTING ON the likes of Amidinijaad, Assaid & Kim Jong?"
Gee, Jonatahn, I didn't think there were any Lockheed-Martin, Boeing, Raytheon, General Dynamis, TRW and such connections with any of those governments. If there were, we'd be sitting down with them to play "Let's Make a Deal." They aren't Facist or Corporatist. But, admittedly autocratic/dictatorships.
No, Jonathan, you know very well that my remark refers to OUR corrupt/influence-peddled cadre operating from 1600 Transylvania Avenue.
Here's a little Pro Bono advice: Nancy Pelosi for President, NOW!! Translate that, Jonathan.
by K1CJS on May 31, 2007 Mail this to a friend!
Pelosi for president? We've already shot ourselves in the foot by re-crowning Dubya--now you want us to hack our leg off?
by W9WHE-II on June 1, 2007 Mail this to a friend!
So Lee, I guess that means you prefer to deal with minicial, America hating, radical, extremist socialist dictators like Amidinijad, Assaid & Kim Jong. All I can say is Wow.
And as for Nancy Pelosi for president, why bother? There is already one autocratic, dictatorial, USA hating extremist socialist candidate running for US president...and her name is Clinton. One is not enough for you?
RE: ARRL LIKELY to prevail.
by W6EM on June 1, 2007 Mail this to a friend!
W9WHE-II, Jonathan pens:"So Lee, I guess that means you prefer to deal with minicial, America hating, radical, extremist socialist dictators like Amidinijad, Assaid & Kim Jong. All I can say is Wow."
Nope. You guessed wrong, Jonathan. I don't like Facist, Socialist, Communist, Corporatist or any flavor of dictator.
"And as for Nancy Pelosi for president, why bother? There is already one autocratic, dictatorial, USA hating extremist socialist candidate running for US president...and her name is Clinton."
I'd say you made quite an error in claiming that these two immensely competent women are what you describe them to be. If you want to describe people who put the American people first, ahead of multi-national corporations, as, well, socialists, then, God bless them all. We need more of them.
The Preamble to our Constitution starts with "We the PEOPLE," Jonathan, not "We the Corporations." Perhaps, Jonathan, to you, its as Bush retorted: "It's just a @#$% piece of paper!"
by STRAIGHTKEY on June 1, 2007 Mail this to a friend!
"We've already shot ourselves in the foot by re-crowning Dubya--now you want us to hack our leg off?"
Anyone is better than dubya....*ANYONE*!
by W9WHE-II on June 4, 2007 Mail this to a friend!
Anyone that listened to Mrs. Bill Clinton's recent speech wherein she wants to replace our "on your own" society, with a "shared responsibility for shared prosperity," society and does not believe that she is a Marxist-socialist, is just denying reality.
Mrs. Bill Clinton wants to enact that old economic philosophy:
"From Each according to their abillity, to each according to their needs"
(Karl Marx)
by W6EM on June 5, 2007 Mail this to a friend!
Sounds like she's advocating the Citizen Corps to me, Jonathan. Or a new form of volunteerism.
As StraightKEY said, anybody'd be better than the Dick-tator and Dumb-tator pair we now have.
I just heard that the Dumb-tator is ready to pardon his henchman, before he serves any of his 30 months of jail time. That'll be the lynch-pin for Impeachment.
RE: ARRL UNLIKELY to prevail.
by W9WHE-II on June 6, 2007 Mail this to a friend!
Lee:
Interesting that you bring up pardons.
Bill Clinton pardoned Mel Reynolds, a convicted child molester, it was OK with you liberals. What Libby allegedly did was NOTHING by compairison. But then again, in a liberal's mind, liberals can do no wrong.
by STRAIGHTKEY on June 8, 2007 Mail this to a friend!
"Bill Clinton pardoned Mel Reynolds, a convicted child molester, it was OK with you liberals. What Libby allegedly did was NOTHING by compairison. But then again, in a liberal's mind, liberals can do no wrong. "
W9WHE, it seems your lack of accuracy goes beyond ham ham radio issues. Clinton did pardon Reynolds, but it was on bank fraud charges unrelated to the molestation conviction. He had served his time for the molestation of a 16 year old and had partially served time for the bank fraud charges. When you compare what Reynolds was pardoned for (bank fraud) versus Libby's crime (four felony counts related to a CIA leak) your statement above doesn't hold much water.
I'm not downplaying what Reynolds did or saying Clinton was right in pardoning him, I'm merely pointing out how amazingly inaccurate your post is. By the way, how's your research on those exorbitant ARRL salaries coming along?
Bright Spot -- Ray Grob NN8R:
