'The Doctor Is In' the ARRL Letter:
from
The ARRL Letter, Vol 27, No 19
on
May 16, 2008
Website:
http://www.arrl.org/
This week, ARRL Letter readers are in luck! The ARRL's very own Doctor,
author of the popular QST column "The Doctor Is IN," answers a question
from his mailbag:
Question -- Mel, Snyder, K8MIW, of West Olive, Michigan, asks: I have a
question about feeding a folded dipole, spaced about 5 inches between
wires. What would be the difference between feeding it with the usual
300 ohm twin lead and using the popular 450 ohm window line as a feed
line? I operate mostly on 75 meters. Years ago I used a folded dipole
and found it to be an effective and wide band antenna. I have heavy duty
window line on hand, but would have to buy the twin lead and the only
line I can find is light duty line. Would the mismatch with the 450 ohm
line cause any problems?
The Doctor answers -- The most significant difference would be the level
of mismatch at the transmitter end. If you are using an antenna tuner, I
doubt that you will notice any difference at all.
There will actually be slightly less loss with the 450 ohm (usually
closer to 400 ohm in my experience) line. Let's see, if the antenna is
about a quarter-wavelength high, the actual feed impedance will be
closer to 200 ohms than to the free space value of 300 ohms. With 300
ohm line that results a 1.5:1 SWR at resonance, or 2:1 with 400 ohm
line.
I would go ahead and use the window line. It should be less bothered by
rain and will probably last longer. If your tuner has a problem at any
frequency you operate at, try changing the feed line length by 20 feet
or so and see what happens -- you are likely to find a length that works
across the band. Just don't roll up any excess. In my cellar shack, I
usually put any excess window line between the overhead floor joists,
away from other wires and secured with TV standoff insulators.
That should be a great antenna! You may even be able to tune it on other
bands, if you have a wide range tuner -- especially 30 meters. On that
band, the window line will make even more of an improvement.
Vol. 27, No. 19
May 16, 2008
There are no comments on this article:
Post One
Amateur Radio Grants Help Bob Jones Set Up Station:
11-Meter Radio Mast Gets Thumbs Up from Planners:
Attorney: City Plan Violates Law:
Middle School Looks to Start Ham Radio Club:
Mile High Radio Club Connects the Mountain:
