How to Win an ARRL 160m Contest for WTX
Sam Morgan (K5OAI)
on
November 4, 2009
Yesterday, 10/27/09, when I opened my mail, I received a pleasant surprise from the ARRL.
There was a certificate for winning 1st place for the 2008 ARRL 160 Meter Contest, while running Class A (QRP) from the WTX section.
After I bask in all that glory for a few moments, it occurred to me to check and see, how my scores compared to other stations who also played in the 160m contest.
First I found that out of 1280 entries I placed 1121st
Next I found I placed 65th out of 77 class A (QRP) entries.
Summarizing, my points score was 1,428, made 45 QSO's, contacting 17 multipliers/sections. Looks like I blew 7 contacts, loosing 2 additional sections, to lose 510 points from what I thought I had scored at the end of the contest. QRN, QRM, op error, who knows, it happens.
To see the scores for the WTX section I used the ARRL's Interactive Contest Scores page.
http://www.arrl.org/members-only/contests/scores.html?con_id=163#change
The results of the search can be seen below:
Scores Table Key
Class
A - Single Op QRP
B - Single Op Low
C - Single Op High
D - Multioperator
Summation of *all* WTX entry's follows:
Section
WTX
Entries 1 to 5 of 5 listed
Call
Score
QSOs
Mult
Class
Section
Club
Ops
1
KA5OAI
1,428
45
17
A
WTX
2
N5DO
39,910
308
65
B
WTX
3
W5JMW
35,564
266
68
B
WTX
4
NZ5M
598
23
13
B
WTX
5
W5ZO
41,536
331
64
C
WTX
and to summarize and conclude today's lesson,
in how to be the winning QRP station for the WTX section, for the 2008 ARRL 160 Meter Contest.
/insert drum roll please
Be the only person silly enough to enter a 160m contest from WTX running QRP with *65mw* into a *13.5* foot tall antenna @ 20 feet!
P.S.
Here were my soapbox comments after the contest:
KA5OAI -- Dec 9, 2008 13:21 ET
It seems I was one of perhaps 9 stations that put our WTX section on the air in
last weekend's ARRL 160m contest. N5DO, NZ5M, K6SXA, W5JMW, K5TDA, K5XM, W5ZO,
KD9KC, KA5OAI
Heres a summery of play time from the San Angelo, Tx. side of WTX
"Modest WTX QRP effort"
I finally got to play in my first 160m contest since becoming an apartment
dweller many years ago. It took 5 years to get the landlords approval for *any*
antennas allowed, and then 2 more years to get a Hi-Q 5/160 antenna installed
for 160m on the apartment buildings second floor roof at 20 feet.
The Hi-Q is an excellent antenna. Above the 5/160 coil my installation has a
EB-8 tophat and a 102" whip, so it's all of about 13.5 feet tall. For the ground
plane there are sixteen radials each 13 feet long, with a wire connecting the
outer ends of the radials. There is one radial each for 160m, 80m, 60m, 40m, and
30m thrown in there for grins, all laying on the tar and gravel roof at 20 feet.
If you take my Elecraft K2's 5 watts output, times the Hi-Q's 1.3% efficiency on
160m, we end up with an approximate effective radiated power of about 65
milliwatts. Can you say, WTX section powerhouse, *NOT* hi hi.
By about 1AM local time of the first night I had worked everyone that could hear
me, all 25 of them. Saturday morning added about 14 more to the log Sunday
morning, 4AM local started with about an hour of no Q's, I figured I was done.
Then came KF4T, who deserves a very big thanks for working so hard to dig me out
of the noise. He broke my no contact streak, and I managed to get another 10
stations in the log by daybreak.
End result 52 Q's, 19 sections, and 1,938 total points, all with 65 milliwatts
and a 13.5 foot tall vertical at 20 feet. Who said you can't have fun on 160m
from a mid town apartment, next to a power utilities sub-station, while
surrounded by lots of commercial store RFI?
Maybe next time I can get the locals to give me a contact for WTX, I never heard
any of the other ones on the band all weekend. It's a pretty simple exchange,
all you need is "599 WTX" only 6 letters to learn in cw.
It seems my best contact of the 160m contest was with W4MYA 1345.56 miles away
from San Angelo, TX in Goochland, VA (no I didn't make that up) which turns out
to be 20700.97 miles per watt.
Pics of the Hi-Q installation can be found on links from my home page
http://pages.suddenlink.net/k5oai/index.html#ant
P.S. My hats off to all those that did all the hard work copying my peanut
whistle, those guys/gals were the greatest! -- KA5OAI
Add A Comment
Reply
by N5TGL on November 4, 2009
Mail this to a friend!
Great story and great writeup. Like I've always said, you always miss 100% of the opportunities you don't take!
Good work and congrats!
Reply
by AB2RC on November 4, 2009
Sounds about the same as my entries to the 2005 & 2006 November Phone Sweeps, I was the only QRP entry in Southern NJ, so win was by default....
If you don't enter your log, you cant win.
Maybe I will try again this year.
RE: How to Win an ARRL 160m Contest for WTX
Reply
by WA8MEA on November 4, 2009
OK....we're taking an "office pool" bet to see which one of the "regulars" first utters those infamous words:
"LIFE IS TOO SHORT FOR QRP!"
The phrase should be filed away with these other outdated words/phrases:
* "Here's the 411 on this."
* "Thank you for taking my call."
* "....if you will...."
* Any utterance from a teenager with the word "like" used at least twenty times in the oration....
* Glenn Baxter and his overuse of "uh". (Someone said Glenn's up to 24 UPM. That's 24 Uh's Per Minute....)
Have I missed any????
73, Bill - WA8MEA
http://HamRadioFun.com
Reply
by WB2TPS on November 4, 2009
Good for you...
I won the NLI section award for the 160 contest several years ago...the same way...
I like the 160 contests. My amp doesn't cover 160 so it is 100watts to a G5RV fed as a marconi. A really crummy antenna.
Thanks to all the guys who take the time to dig my piss weak signal out of the mud....
Reply
by N0AH on November 4, 2009
All equipment being the same, Right location defined by minimal QRN compared to everyone else during the contest--
Reply
by K0BG on November 4, 2009
Hey! Great! You've epitomized exactly how most mobile operators would feel if they made a contact on 160 meters. If they only knew, that is.
Reply
by NI0C on November 4, 2009
Nice job, Sam. Don't miss the QRP ARCI Topband Sprint, which is 0000 to 0600 UTC Dec. 3. Two way QRP on topband is great fun.
Chuck NI0C
Reply
by W8EH on November 4, 2009
Good job. QRP on 160 isn't the easiest thing to do.
I did a similar thing in the CQ WPX CW a couple years ago and won a single band QRP class.
Reply
by K1BXI on November 4, 2009
For what it's worth, I won the Maine section in the 160 meter cw contest 50 years ago with 3 contacts! (I was the only one to send in a log)
But not QRP by todays standard, and only had 25 kHz to play with and fight the LORAN pulse signal up here on the North East coast.
Used a DX100 and a dipole. 90 watts out, which I believe in those days anything under 100 watts was considered QRP (maybe that was input power though)
Top band operations sure have improved since then.....
John
Reply
by WT0A on November 4, 2009
Kind of like being 1st in Ne. But check midwest div class A
Glen WT0A
Reply
by K3AN on November 5, 2009
Only one station can win a contest, and only one station can come in first in each ARRL section or other geographic multiplier. But all of us can try to improve our station, our stamina, our tactics and our copying skills in order to get a higher score than we got last year.
It's sorta like golf. Each stroke I shave off my handicap is an achievement. Will I ever play on the PGA Senior Tour? Nope.
Reply
by K1TN on November 5, 2009
Nice building-top antenna installation. Congrats on sticking with it and finally getting permission.
You story did not (directly) mention that you accomplished your feat on CW.
You did not mention if you could hear a lot of stations that you couldn't work. I bet that's the case; think how many more you could have worked with a little more power.
In December 2006 on a drive through south New Jersey I stopped at the W2GD superstation operation in the ARRL 160 Meter Contest on Sunday morning. One of the guys there had a mobile setup and I worked W2GD from it, in the parking lot, using my call sign. I submitted the one-QSO "log" and got the certificate for SNJ Section, QRP. I've done contest operations where I made 3,000+ contacts and did not get a certificate.
These days, I work CW contests from an apartment with a 66-foot end-fed wire and 100 watts output and work hundreds of stations, worldwide, in a weekend. I don't waste my time on SSB or RTTY. Last year in the ARRL and CQ 160 contests I worked about 175 stations in each, mostly just on the second night.
Jim Cain, K1TN/2
Reply
by G0GQK on November 5, 2009
Ref, outdated phrases er... that is a given. What is a given ? While I'm at it, why does everyone when talking about any subject under the sun, always have to include ishoo ?
G0GQK
Reply
by KB2HSH on November 18, 2009
FANTASTIC!
As a Novice in 1988, I had dreams of utilizing 160 (besides the female dreams...hihi).
This is sage wisdom as the ARRL 160 Meter Contest approaches.
Congrats, and see you on Top Band.
John KB2HSH
Holders of Expired Novice, Tech Licenses Eligible
IARU Represents Hams at WRC-2000
FCC Feeling Restructuring's Impact
Lew McCoy, W1ICP, SK (updated)
Is 'Nothing' Better?
Other Contesting Articles
Announcing the Contest Compendium
Digital Modes for Field Day
A Sleep Strategy for DX Contesting
GM0B -- CQ WW SSB 2008
Contesting in Ham Radio
