Propagation Forecast Bulletin #44 de G0KYA:
from
W1AW Bulletin via the ARRL
on
October 30, 2009
Website:
http://www.arrl.org/
ZCZC AP44
Propagation Forecast Bulletin 44 ARLP044
>From Steve Nichols, G0KYA
Wymondham, England October 30, 2009
SB PROP ARL ARLP044
ARLP044 Propagation de G0KYA
The propagation bulletin this week is written by Steve Nichols,
G0KYA, of the RSGB's Propagation Studies Committee in the English
county of Norfolk. K7RA is out of town and will return next week
for the November 6 Propagation Forecast Bulletin ARLP045.
Well, what a week it has been. The solar flux hit 82.3 on Tuesday,
the highest recording yet since the first observed "new cycle
sunspot" in January 2008, which was the "official" visual start of
Sunspot Cycle 24.
Even as I write this, the flux is still at 80, thanks to sunspot
region 1029, so let's hope that it is a sign of better things to
come.
The region (1029) produced several B-class solar flare events and a
single C2.2 class flare on the 28th, but luckily CQ World Wide SSB
was unaffected for the most part.
NASA's STEREO "behind" spacecraft is not showing any new spots
coming around the solar rim, but we live in hope. I was lucky enough
to record a Podcast with Carl Luetzelschwab, K9LA at the RSGB's
Convention in the UK where he talked about Solar Cycle 24 and the
possible effect of galactic cosmic rays on Top Band propagation. You
can hear the Podcast at,
http://www.g0kya.blogspot.com.
In the UK a combination of sporadic-E and F2 layer propagation made
10 meters a "must have" band for contesters last weekend. The 28 MHz
band was full of European stations and I personally worked more than
25 countries in two hours of casual operation. Longer DX included 4X
(Israel) and ZS9 (South Africa) with signal strengths peaking at 59
with very simple antennas. I can't remember the last time 10 meters
was so active, although it was interesting to note that on Monday
the band was completely clear. It just shows that you should call CQ
once in a while.
Tim, K6GEP reports that he and other Southern California amateurs
worked YO4ATW on 10 meters around 1930z on October 25 during CQ
World Wide SSB. No other European countries were heard on the band
at that time. Only 100 watts and modest tri-band yagis were used at
both ends.
Marcel, YO4ATW was a single band entry on 10 meters, and made over
340 contacts, including some in South America. On another day this
week, he worked some Brazilians around 1800z. Multi-hop Es or F
layer? Let's hope it is a pointer towards better things to come.
Al, AB2ZY also found 21 MHz wide open. From the Adirondacks in upper
New York state with a single ground-mounted Butternut HF6V vertical
with lots of radials, an ICOM 756 Pro III transceiver and an old
Yaesu FL-2100B amplifier, he was hearing Western European stations
well after their sundown.
At the other end of the spectrum 80 meters was also a great band
with many US and Canadian stations giving novice European operators
their first trans-Atlantic QS0s around 3.8 MHz. K3LR in PA was still
audible more than one hour after sunrise in the UK.
Let's hope we get similar conditions for CQ World Wide CW in
November.
K7RA--and normality--will be back next week.
73 de Steve G0KYA
If you would like to make a comment or have a tip for our readers,
email the author at,
k7ra@arrl.net.
For more information concerning radio propagation, see the ARRL
Technical Information Service web page at,
http://www.arrl.org/tis/info/propagation.html. For a detailed
explanation of the numbers used in this bulletin see,
http://www.arrl.org/tis/info/k9la-prop.html. An archive of past
propagation bulletins is at,
http://www.arrl.org/w1aw/prop/.
Monthly propagation charts between four USA regions and twelve
overseas locations are at
http://www.arrl.org/qst/propcharts/.
Sunspot numbers for October 22 through 28 were 0, 30, 21, 28, 29,
29, and 26 with a mean of 23.3. 10.7 cm flux was 71.6, 72.9, 75.6,
75.5, 81.3, 81.5, and 79.9 with a mean of 76.9. Estimated planetary
A indices were 14, 8, 8, 5, 3, 3 and 2 with a mean of 6.1.
Estimated mid-latitude A indices were 12, 7, 5, 3, 3, 2 and 3 with a
mean of 5.
by AE6RO on October 30, 2009
Mail this to a friend!
Maybe Cycle 24 really has started when the solar flux hit 84! 73, John
RE: Propagation Forecast Bulletin #44 de G0KYA:
by KB3HJK on October 30, 2009
I'll go way out on a limb - it will be 68 within days.
Kevin
by AE6RO on October 31, 2009
Gosh, I was so sure the sunspots are coming back! Oh, well they've got to come back sooner or later! Don't you think?
The few hams I've talked to think so, but most lay people just roll their eyes and go to sleep when you talk about sunspots.
How am I doing? Does this read nutty enough?! John
New Vice Directors in Central, Roanoke Divisions:
New Amateur Radio Web Site Launches:
Announcing Railroad Depots on the Air:
Rowley Shears, G8KW (SK):
Cuba Facilitates Equipment to Amateur Radio Operators:
