The Internet Radio Linking Project
Paul Cassel (VE3SY) on July 24, 2001
usi
Another Canadian Invention Sweeps the World
Thanks to an innovative Canadian, we now have a new and powerful recruitment tool for the younger generation interested in technologies like the Internet, Linux and Ham Radio. By enabling the new IRLP technology to our standard FM repeaters we provide instant on-demand-linking with one or more repeaters world-wide. And if you're concerned about cost, this entire project is definitely within a Ham Approved -cheap- budget of under CA$200 including hardware and software.
IRLP is the brainchild of David Cameron, VE7LTD of Vancouver BC. IRLP is the abbreviation used for the Internet Radio Linking Project which David developed over the past several years. Back in 1998 Dave became frustrated with the unreliable operation of the Windows based Voice over IP software. All Windows based amateur linking software used VOX and were not secure from non-amateur access. The IRLP network uses a digital switching concept and produces an instant and secure link between licensed repeaters all around the world.
Eight months after Dave started his design work in 1998, the IRLP network was born and is now on Version 2.0 of hardware/software. As of this printing, IRLP will be serving well over 150 nodes and growing in leaps and bounds. When we ordered our interface hardware here in Kitchener this past February there were 63 active nodes with 26 other new node orders shipped with our package.
How It Works
David's custom IRLP software -takes the audio from the receiver which is fed into the sound card - where it is converted into ADPCM digital data the same format used by the phone companies for Long Distance service. The Linux PC then converts this digital information into digital packets each assigned with IP addresses for the destination node. These packets now flow through the internet to the destination Linux PC where the packets are decoded then sent to the sound card and out to the transmitter microphone of the link radio which then transmits the audio out over the local repeater. The transmitter is keyed as soon as these TCP/IP (Internet Protocol) packets start to arrive. As soon as the data stops the link radio automatically un-keys and process reverses.
0x08 graphic
The underlying audio processing technology in IRLP is a freeware application called Speak Freely. Speak Freely produces Voice-Over-IP (VoIP) audio streaming and is very similar to other VoIP software packages such as Microsoft NetMeeting and the VocalTec iPhone with one major difference - It runs under Linux not Windows. Linux was David's operating system of choice for the IRLP system as it allows the best in reliability, programability, efficiency, and functionality. Since our repeaters don't need anything even close to MP3 audio quality, IRLP is using a low-bitrate VoIP to communicate. Most nodes use an encoding system that requires only 32KB/s of bandwidth, however some nodes with extremely limited bandwidth, use a GSM encoding method which only requires 17KB/s albeit at the cost of audio quality.
The control of the radio is performed using a small custom logic board build by Dave VE7LTD which is connected to the computers parallel port. This board samples the received audio for Touch Tone audio, detects when the link receiver is active, and feeds the TX PTT line to the link radio. All of the command I/O between the PC and the IRLP board is handled by a connection to the PC's parallel port.
The whole system is DTMF (touch-tone) controllable. The control codes lie imbedded in a separate program that reads the DTMF tones from the decoder located on the interface controller board and activates various parts of the software. DTMF codes are used to enable/disable linking, open/close links and set identifiers. Every site has the ability to connect direct to any other site(s), either using direct connections or reflector sites.
To host an IRLP node you require; a) a full time high speed Internet connection - DSL or Cable works well - b) a dedicated Linux computer - a 486 DX100 or better is required, c) the IRLP custom software/hardware and d), a link radio or direct connection to a repeater. Each node on the IRLP network is assigned an ID code and a central server keeps track of the IP addresses in use by all nodes. (IP= the routing code used by all packets of data flowing on the internet)
The Kitchener Ontario IRLP Node
I had read about Dave's work on his web site and based on the low cost of entry US$120 I ordered the IRLP package which arrived within 10 days.
Paul VE3SY interfacing the IRLP board between the GE Phoenix link radio and the LINUX computer The audio levels are important and were set using the old Cushman CE50 service monitor.
The first thing I had to do was sacrifice my Windows 98 based P133 machine in favour of the Linux operating system for which I had no previous experience. Following the very detailed installation instructions posted on the IRLP web site, the installation went very smooth however I did encounter a weird inbound Telnet problem that was quickly resolved thanks to assistance from Dave VE7LTD and our resident K-W Linux guru Dave VA3DGS.
Now that I had the Linux box talking both ways to the internet I had to install the IRLP hardware and a Windows based Plug-n-Play SoundBlaster card. Since many hardware manufacturers do not yet "support" this most powerful operating system, this is where my fun began. The sound card wanted to use the same machine resources used by the Ethernet NIC card causing interesting issues such as trashing my BIOS settings and leaving the machine almost brain dead. After a day I was able to locate a DOS utility which I put on a DOS boot disk and booted the now Linux box in DOS and changed the conflicts. The machine then booted flawlessly under Linux and recognized the sound card immediately. I was now ready to go on the air however Dave VE7LTD, the IRLP project leader was off sick and unable to send me node access codes.
The next morning "AJ", VE3ABZ checked in and indicated he had codes from the London club and keyed in the four digit code to bring up VE3SUE in London. Typical of many repeaters these days, no one was on the air so AJ then brought up the Denver reflector - a Reflector is a Linux based PC sitting on some serious bandwidth that allows multiple audio streaming out to many repeaters. Now connected to the reflector we were able to talk with amazing clarity to stations in California, Pennsylvania and Yellowknife in the NWT. The audio was awesome and anyone listening would swear the Yellowknife station was in Kitchener not the North West Territories in minus 35 degree weather.
Using the IRLP Network
To connect to another node (repeater) you simply dial a 4 digit on-code. Within a few seconds that node will ID in plain voice with it's callsign and location. If the node is currently connected to another or to a reflector, you will receive a recording telling you which connection the other node (repeater) is currently engaged with. As of press time there were over 150 IRLP nodes QRV around the world with over 8 repeaters in Australia linked full time.
Before placing a call you can always check the status of any node in real time by going to http://status.irlp.net and look at the node you wish to connect with. This page updates in real-time and refreshes every minute so it is always current.
Just as with any linking system, IRLP is subject to some minor audio delays which are mostly radio related. These delays are caused by the amount of time it takes for numerous radios to decode the Tone Squelch information so the first thing to remember is to slow down and be patient. (to dispel internet delay myths, the audio delay over the internet is the same as you experience when using a digital cell phone)
When completed with a QSO announce your call and dial the 4 digit OFF code at which time a voice ID indicating the link is dropping will play. Since many repeaters are not heavily used, there are always a number of nodes left connected to the Denver CO Reflector allowing you to place a CQ, or ORZ type call with an excellent chance to speak with someone somewhere in the world.
IRLP Reflectors
A reflector is a server that allows multiple nodes (repeaters) to be linked together at the same time. As of press time there were 5 reflectors located in Toronto, Saskatoon, Denver Colorado, Yellowknife and Sydney Australia. The most common world-wide reflector is in Denver CO. Most reflectors are hosted by public service minded companies who have lots of bandwidth to support the requirement of a reflector. The amount of bandwidth required for a reflector is directly related to the number of connected nodes. During one Sunday evening net with 25 nodes connected the bandwidth being used on the Denver reflector was just about 1mb. This reflector usually has a number of Canadian, US, Australian and Caribbean repeaters connected so any conversation that occurs on one is heard on all connected stations.
The Sunday evening net (alternates between 01:00Z Monday and 16:00 Sunday every other week) is a great place to listen for check-ins from around the world. For those outside of IRLP coverage repeaters, a streaming audio feed is usually available on the internet. Point your browser to www.kwarc.org/irlp/listen.html for info.
CANWARN net controllers in Southern Ontario are linking themselves via IRLP using the new Ontario Reflector hosted by Group Telecom in their Toronto Central Office. This allows the CANWARN controllers to rapidly exchange severe weather information between themselves and the Environment Canada Toronto Severe Weather Desk without interfering with the local CANWARN nets. (CANWARN is the Canadian SkyWarn system)
Active nodes around the World
The following chart lists repeaters that are active around the world.
VE6RJZ
Canmore
AB
VE6MPR
Banff
AB
VE6WRT
Calgary
AB
VA6IRL
Lethbridge
AB
VE6SBR
Edmonton
AB
VE6TE
Red Deer
AB
VE6ZV
Calgary
AB
VE6TRC
Ft. McMurray
AB
VE6RPT
Calgary
AB
KB8JXX
Anchorage
AK
W7FDF
Tucson
AZ
N7CK
San Manuel
AZ
VE7MFS
Coquitlam
BC
VE7VIC
Victoria
BC
VE7RNA
Chemainus
BC
VE7BHI
Port Alberni
BC
VE7TSI
Kamloops
BC
VE7REE
Penticton
BC
VA7OKN
Vernon
BC
VA7RDX
Vanderhoof
BC
VE7URG
Vancouver
BC
VE7RGF
Grand Forks
BC
VE7FFF
Prince George
BC
VE7RVN
Vernon
BC
VE7RHS
Vancouver
BC
WA6SUP
Sacramento
CA
WB6EGR
Burbank
CA
KU6V
Fremont
CA
KD6GDB
Santa Monica
CA
K6UB
Saratoga
CA
WD6AWP
Huntington Beach
CA
KE6PCV
Los Angeles
CA
WA6RQD
Oceanside
CA
K6JSI
San Diego
CA
VE6RGP
San Diego
CA
WA4HND
Grand Junction
CO
REF2
Denver Reflector
CO
NOPSR
Denver
CO
WA3KOK
Washington
DC
K4KSA
Tampa Bay
FL
KD4BBM
Miami
FL
KD4Z
Orlando
FL
W4DOC
Atlanta
GA
N4NEQ
Atlanta
GA
KH6GMP
Kailua Kona
HI
AH6GR
Maui
HI
AH6JA
Hilo
HI
AH6CP
Honolulu
HI
K7OJI
Fruitland
ID
W9DXN
Dixon
IL
K9WZ
Plymouth
IN
VE4UMR
Winnipeg
MB
VE4SRR
Swan River
MB
W1IMD
Portland
ME
WB8NXP
Bloomfield Hills
MI
N8DNX
Stutsmanville
MI
KC8NCE
Grand Haven
MI
KB3HF
St. Peters
MO
AC7DE
Helena
MT
VE9MCH
Fredricton
NB
KF6SWL
Omaha
NE
VO1BWP
Corner Brook
NF
VO1HHR
Grand Falls
NF
VO1KEN
St. Johns
NF
KA2JZO
Brown Mills
NJ
VE1WRC
Amherst
NS
VE1NSG
Halifax
NS
VK2RMR
Mt. Riverview
NSW
VK2RCZ
Sydney
NSW
REF5
Sydney
NSW
VK2RMP
Wollongong
NSW
VK2RBM
Sydney
NSW
VK8RTE
Darwin
NT
REF4
Yellowknife
NT
VE8NWT
Yellowknife
NT
VE8YK
Yellowknife
NT
AB7TJ
Minden
NV
W7AOR
Las Vegas
NV
NV7RM
Reno
NV
K1IMD
E. Long Island
NY
K1IMD
NY
WR2ROC
Rochester
NY
W8HDU
Lima
OH
VE3KAR
Kingston
ON
VE3ULR
Toronto
ON
VA3RVU
Brampton
ON
VA3MME
Omemee
ON
VE3ORX
Orangeville
ON
VA3CWS
Richmond Hill
ON
VA3LU
Thunder Bay
ON
VE3RBM
Kitchener
ON
VE3MUS
Huntsville
ON
VE3RAK
Toronto
ON
VE3OD
Halton Hills
ON
VE3SUE
London
ON
VE3PGC
Cornwall
ON
VE3DPL
Norwich / Delhi
ON
VE3ADT
Toronto (Milton)
ON
REF1
Toronto Reflector
ONT
AH6LE
Mt. Angel
OR
KA3KCJ
Downingtown
PA
KA3VMA
Drexel Hill
PA
N3IO
Philadelphia
PA
N3APP
Erie
PA
KF3DY
Wellsboro
PA
VA2RLP
Baie-Comeau
QC
VE2TPE
Baie-Comeau
QC
VE2RJS
Montreal
QC
VE2BRR
Montreal
QC
VK4RKP
Ipswich
QLD
N4GLB
Upstate
SC
VE5MLR
Meadow Lake
SK
VE5RAD
North Battleford
SK
VE5CC
Saskatoon
SK
VE5WM
Regina
SK
VE5IOU
Prince Albert
SK
REF3
Sask Reflector
SK
VE5SKN
Saskatoon
SK
GB3US
Sheffield
SY
G4NJI
Rotherham
SY
WB5TUF
Houston
TX
WB6ARE
Cedar Park
TX
G4CUI
Sheffield
UK
WX7Y
Castle Dale
UT
KA7STK
St. George
UT
KD7EFG
Murray
UT
K7SDC
Castle Dale
UT
VK3TNB
Melbourne
Vic
VK3RGL
Melbourne
Vic
J73CS
Roseau, Dominica
W Indies
J73D
Roseau, Dominica
W Indies.
VK6RFM
Fremantle
W.A.
VK6RNC
Perth
W.A.
N7BFS
Spokane
WA
W1CDO
MOBILE
XX
VY1RHJ
Haines Junction
YT
VY1RW
Whitehorse
YT
As for DX stations you can look for two nodes in The Commonwealth of Dominica (not the Dominican republic) where it's not unusual to hear Bernadine, the Mayor of the capital city Roseau on the air promoting the Island. As well you may hear J79 stations on from St. Lucia accessing the Roseau repeater across the Caribbean. As well, there is lots of activity from the 8 active nodes in the land down under which reminds you of the movie Back To The Future as most QSOs with VK land are taking place tomorrow.
Summary
Where else can you witness an open world-wide VoIP wireless network using a free and open protocol like IRLP? This exciting new technology will be a tremendous catalyst to bring new young blood into our hobby. As we all know there has been a real challenge for us to draw kids into our hobby as they could previously talk on their poor quality iPhone connections over the Internet. Now with a basic HT they can enjoy far superior audio and be talking with their friends across town and around the world.
Since we brought our node on here in Kitchener our membership has taken a real boost. Many former members see the excitement back in the hobby and many new members are joining to be part of the IRLP system. The VE3RBM repeater has gone from possibly 2 QSOs per week to our busiest repeater and is dedicated to IRLP use. It is highly recommended that an IRLP node not be added to a high traffic repeater unless the reflector feature is locked out which is easily done.
Are You Interested?
If this article has piqued your interest and you seek additional information please browse the official IRLP web site at www.irlp.net and feel free to contact the IRLP designer Dave, VE7LTD at dcameron@irlp.net or the author at paul@ve3sy.com .
References:
http://www.irlp.net Internet Radio Linking Project web site
http://www.kwarc.org/irlp/listen.html Streaming Audio feed of IRLP
  • - 30 -
Author: Paul Cassel VE3SY
Box 29 RR2
PETERSBURG, Ontario
N0B 2H0
Canada
