Do you have an idea or a simple project that has improved your operating? Maybe you've taken something commonly found around the home and developed a ham radio use for it? Why not share your hints with fellow hams in "Hints and Kinks," a monthly column in QST. If we publish your hint in QST, you will receive $20. Send your hints via e-mail h& or to ARRL Headquarters, Attn: "Hints and Kinks," 225 Main Street, Newington, CT 06111. Please include your name, call sign, complete mailing address, daytime telephone number and e-mail address.
I have been looking for a project like this that I could use to get a wire antenna up about 35' or so. I had been considering the SATERN Pushup Pole Project using nested EMT Conduit ( )which would be secured to a 4x4 post then guyed.
Mike, K4MOA
Ham 2 Last:
