Mike, K4MOA
Prince Edward Island Man Set to Compete in World Radio Team Championships:
Competition Keeps North Hills Amateur Radio Club Talking:
Waldo County Hams Well-Equipped, Skilled In Emergency Communications:
Norwell One of 16 Sites for World Radiosport Team Championship:
Amateur Radio Club Attracts Tech Experts:
