Mike, K4MOA
IARU Addresses New Radio Spectrum Pollution Threat:
S-24 Pgns Admin Urges Ham Radio to Reunite Nepali Man:
Ham Talk Live #82 -- Public Relations:
New Plymouth Amateur Radio Celebrates 90 Years On Air:
