6-Meter Square Copper Dipole
from George W Dowell, K0FF on January 12, 2012
"Editor's Note: Due to the popularity of some of eHam's older articles, many of which you may not have read, the eHam.net team has decided to rerun some of the best articles that we have received since eHam's inception. These articles will be reprinted to add to the quality of eHam's content and in a show of appreciation to the authors of these articles." This article was originally published on: 9/14/2000
Here is the parts list and dim. sheet for a 6m Square Copper Dipole, made
from copper water pipe.
Characteristics:
It is more or less omni-directional, and horizontally polarized.
Copper is the best possible electrical conductor at normal temperatures, next to silver.
It presents a high angle of takeoff when mounted low, and singly (great for Es), and can handle 100W. Stack two or more for extra gain if needed.
The Gamma Match:
A low VSWR may be obtained by adjusting the Gamma Match shorting bracket position, and also the length of the tubing and shorting bracket. The Gamma bracket "finds" the 50 Ohm point along the element, and connects that to the Coax connector via the Gamma tube.
The additional length of tube adds inductance into the circuit, and this is canceled out by the series capacitance formed between the insulated Gamma wire and the inside of the Gamma tube.
Description:
A large (3/4") part is used, and adapted down to fit the water pipe, to increase its insulating qualities, as there is very high voltage at this point. A strip of brass or copper 1/2 by 3" is screwed to the outside middle portion of the CPVC Tee, through a small center hole, and is rotated one way or the other as a resonance tuner (Butterfly). When the Butterfly is at right angles to the element, the frequency is the highest, when parallel, it's the lowest.
A Gamma match sets the impedance to 50 Ohms, and the Butterfly adjusts the center
frequency. Center frequency is 50.00 to 50.800 with the exact dimensions shown
Typically the 2:1 SWR bandwidth exceeds 500 kHz.
Mounting:
A U bolt and saddle through the central tube provides a center mounting point. Another approach is to install a copper TEE in the center tube, with the open end down. In that open end solder a 1/2" brass rod which has been drilled and tapped for 3/8-24.
In some climates where water is a problem, drill small weep holes in the bottom corners.
A spray coat of Krylon Clear Enamel will keep the copper shiny. If used mobile, you may use a colored paint, the same shade as your vehicle.
Construction:
Material:
1/2" Copper waterpipe :
3 ea. 27 inch piece
4 ea. 12.5 inch piece
1 ea. 13.5 inch piece 3/8 i.d. Copper refrigeration tubing ( Gamma tube) *
4 ea. Copper 90 Degree elbow
1 ea. 3/4 CPVC TEE
3 ea. 3/4 to 1/2 CPVC reducer
1 ea. Copper TEE
1 ea. 11" piece of RG8 insides (center conductor and insulation, Discard shield and outer plastic) *
Lay the assembly on a flat surface with the center opening of the TEE facing the middle of the antenna. This is where the first 27" piece (mounting bar) goes in, via a reducer. On the outside edge of the CPVC TEE is where the butterfly attaches. For mobile or portable use, use 3 s.s. #6 screws through each of the CPVC TEE joints for added strength. The rest of the antenna solders together to form a square, using the 90 degree elbows at the corners. Drill small weep holes in the bottom corners of all four 90s to let accumulated water drain out.
The brass plate is bent to form an "L" 1-3/4" tall with a 1/2" lip. A 5/8
hole is provided 1-1/4 inch from the bend, and an SO-239 is attached . Two
small holes are drilled in the lip and the plate is mounted to the copper
TEE with #6 s.s. self taping screws. Attatch the center conductor of a 11"
piece of RG8 insides to the center pin (center wire and plastic dielectric only- remove and
discard shield and outer covering). This is accomplished by soldering or using a screw if
the SO-239 has a threaded center pin *
Slip the other end of the RG8 insides into the 3/8"copper tube 10.5", and tap the copper tube to
the radiating element 13-1/2" from the SO-239 center, with the Gamma tube bracket.
Resonance (center frequency) is adjusted by turning the butterfly.
Mount 15 feet or more high, for home use, and wherever you can for mobile.
An antenna like this can be mounted 3" to 6" above the roof of a vehicle
using CPVC >, PVC or acrylic spacers with suction cups.
Have fun on 6.
*Parts are available in a kit from author which includes all "*" parts, drilled, punched, bent, and threaded, Contact George @ K0FF@ARRL.NET
Don't Eat the Batteries" clause:
Recently my wife and I bought a new TV set, and in the instructions for the hand held remote control the warning said "Don't Eat the Batteries".
SO:
WARNING *
This is antenna is an electrical conductor. Contact with power lines can
result in death or serious injury. Do not install this antenna, supporting mast or tower
structure near any power lines, or where they could come into contact with power lines
should the antenna or structure fall.
Geo K0FF
by K9MHZ on January 13, 2012 Mail this to a friend!
I like it. Nice job.
Funny ending, BTW. Those lithium-ions just aren't as tasty as the old batteries.
by KC8Y on January 13, 2012 Mail this to a friend!
Article was very interesting to read, this morning...I've been looking for an antenna like that :)
by KC2NVL on January 13, 2012 Mail this to a friend!
Perfect timing with the January VHF contest up coming next week-end
RE: 6-Meter Square Copper Dipole
by W0FM on January 13, 2012 Mail this to a friend!
Geo,
According to the local papers it appears that you have returned to your previous habit of obtaining the copper for your antenna kits from the basements of homes in North St. Louis! ;o)
Seriously, are you still providing kit parts?
Terry, WFM
by KE7FD on January 13, 2012 Mail this to a friend!
I dunno, I've always been told gold was a better conductor than copper so I'm building mine out of gold pipe....
Glen - KE7FD
by WB2LCW on January 13, 2012 Mail this to a friend!
I built one. It works FB. I was heard in Scotland
during a band opening last year using this antenna!
by KB4QAA on January 13, 2012 Mail this to a friend!
What was the name of the band?
by W4KVW on January 14, 2012 Mail this to a friend!
The "MAGIC BAND" of course was the NAME of the BAND! {:>)
Clayton
W4KVW
EM80
by K1FPV on January 14, 2012 Mail this to a friend!
Terrific article! I remember about 40 or so years ago when the sunspot activity was high working the west coast using 2 of the old Cushcraft Squalos stacked, and using only 10 watts of AM. The combo worked well. Great project for homebrewing!
Bill/K1FPV
by W2CQ on January 14, 2012 Mail this to a friend!
This was called a "Squalo" in the 1960's. I think Hy-Gain made it but not sure. I mounted mine on the trunk of my Thunderbird.
Ahah! I see that is already in the article and it was Cushcraft. Read everything first then comment!
by N6CAZ on January 14, 2012 Mail this to a friend!
Built a few of these with a friend last summer, and ran into a few discrepancies with the dimensions, but nothing we couldn't work through. My guess is that since the article was originally written, copper supplies and vendors may have changed somewhat. Note also that the author revised the post at least one other time, and since we had never made a butterfly section, the photo was missing from one of the articles.
When we assembled the "T" section, the copper "T" and the CPVC "T" sides left us with something NOT square. My guess is that somehow the copper elbows and "T"s were not adding what they did using the older parts to the lengths. Our parts came from Lowe's and Home Depot, and as we found, only one local Lowe's had CPVC - this is very different from PVC in both color and dimensions.
As is always advised, pre-fit the joints and check measurements BEFORE cleaning the ends of the pipe and adding flux (if you don't, it can bind) and you should be OK.
We also built 2m VHF versions (no butterfly, but end caps at the gap with critical dimensions) and also found the tuning to not be where we expected. Again, be prepared for some trial fit, and the end results are quite reasonable. Of course having an antenna analyzer is also a great time saver!
One tip on the 2m version was to build a square, and not cut the gap end until the joints are done. This keeps it square and flat, as the small pieces may not sit flat after being heated.
Anyone with questions about the dimension changes, feel free to drop me an email. I have the dimensions that worked for us somewhere...will dig them out if anyone needs them.
Happy building!
Jim
N6CAZ
by W8AAZ on January 14, 2012 Mail this to a friend!
If you have meth users next door, it will look like a big shiny copper bauble up in plain view and represent a quick buck at the scrap yard. Better paint it black or keep it electrified with HV at all times!
by AD5X on January 15, 2012 Mail this to a friend!
I built one of these a few years ago. Works great. The only change I made was instead of using the butterfly tuning, I just used aluminum foil duct tape. Then I trimmed the duct tape to get resonance where I wanted it.
Phil - AD5X
by G8ADD on January 16, 2012 Mail this to a friend!
Note for UK readers: this is similar to an antenna supplied by Moonraker UK Ltd.
Brian G8ADD
by KG6YV on January 18, 2012 Mail this to a friend!
In some cultures batteries are an exotic food. I think I saw a show on FoodTV where they used them with eggs instead of pork sausage.
by K6SDW on January 19, 2012 Mail this to a friend!
Nice article, would your antenna be considered a loop? If not, what's the difference......tnx
by W6TVK on February 8, 2012 Mail this to a friend!
I built one of these in 2008, and have been very satisfied with its performance. I also built George's 2-meter version, which works well. Thanks to George K0FF for this design.
by KE4DYG on February 21, 2012 Mail this to a friend!
I have a question would this cooper antenna be better than a delta loop made of wire fed vertical up at just 1 wave length?
2-Element Bent Dipole Yagi
