Where Do I Go from Here?
from
Bob Raynor, N4JTE
on
December 30, 2011
Some thoughts on your first antenna for HF
By Bob Raynor, N4JTE
Okay so you got your ticket and passed the tech exam as your entry into the world of amateur radio,
soooooo are you bored yet? Hope not, because we are finally seeing some sunspots which allow your
new voice privileges to be explored on 10 meters as opposed to the two meter stuff that might not be
quite what you were hoping for. BUT if you have ventured into the next step and got your
General ticket, I would like to give you a basic guideline on your HF antenna possibilities and perhaps
answer a few questions along the way.
Your expectations:
I have been doing the ham thing for a lot of years and my addiction to the hobby may not become the
same for you, but I think it’s safe to say we all want to be heard well enough to have a qso or at least
get a fake 5-9 from a DX contester after yelling back at them in a relatively short time.
That said, once on the air for awhile you will make friends and even be able to recognize their voices
before hearing their callsigns! This is what keeps old farts like me and others coming back to radio at
ridiculous hours, like saying hello to my friend in England G0EVY at 1am or checking in with the HHH
net at 4am local to say hello to friends in Australia and New Zealand. The excitement of being able to
this with some homebrew wire in the trees NEVER gets boring!
It has gotten to the point where I don’t even have to explain these bizarre hours to my xyl, got her
trained, so to speak, as long as the garbage is taken out, mortgage paid, the wood chopped for the
fireplace and the driveway shoveled so she can get to work; while I put up a wire beam for 80 meters
halfway into my neighbors yard, all is fine in my ham world. Yeah right!
Anyway, point of this short article is to try to focus our newly licensed Ham brethren and give you folks
some tried and true antenna advice before you get sucked into buying a commercial antenna you can
build yourself or more importantly avoid wasting hours and money on some magic internet antenna.
Timing is Everything:
As a newly licensed ham, you have joined us after a pretty long dry spell, propagation wise.
Band conditions on the upper bands like 10, 15 and 20 meters are showing some incredible signs of
life. What this means is you don’t need a $5000 tower and beam to speak to another ham half way
around the world, propagation will do most of the work with the antennas I am going to describe and
these conditions should last a few years, and this stuff will cost you less than you might spend for a
month of internet service!
What’s your Preference?
So many frequencies and only so much time to play on the radio! Good time to make some choices, are
you ultimately trying to see how far away you can be heard, or maybe you’ve got another new ham
friend some miles away you want to keep in touch with? Or even maybe you are more technically
inclined and want to explore antenna building or perhaps contesting? Time for you to focus a little bit,
after a little while on SSB you’ll find a niche of interest, BUT; your antenna is your
key element to getting it done. A $2000 radio will become an expensive doorstop without studying,
reading and building the best antenna you can fit in your backyard.
My first choice in antennas has always been some configuration made from wire and usually for two
bands, 40 meters and 80 meters, my reason being that a monoband antenna is easier to build and
easier to match efficiently to your radio, I have designed/ reviewed various multi-band wires, see
“ribbon” and “G5RV” in old eham articles under my call, but the need for a multiband antenna is
probably a good thing for a new ham to explore so I will present a few. BUT; you new generals will have
to take the time to research the actual dimensions and construction, this isn’t a “ how to article,” what I
do want to present is what actually works and will give the most bang for the buck and get you reading
some antenna theory books as opposed to advertisements. Google is our friend if you need more info
on the following antennas or email me at my QRZ page.
Gonna give my choices as based on best to last preference for starter efficient antennas from my own
personal experience at my location, your mileage may vary.
Multiband Homebrew Wire antennas:
CENTER FED DOUBLET
1: Put up the longest, highest, flattest center fed wire you can fit in your yard, nothing wrong with the
ends hanging down near non conductive end supports to add additional length. This antenna needs to
be fed with open feed ladderline and will require a tuner to match efficiently to your 50 ohm radio. If
you can get at least 75% of the length of your lowest band wavelength up in the air, this antenna will
make your day on a lot of frequencies. My first choice for a new ham who wants to explore a bunch of
bands.
FAN DIPOLE
For shape reference only!
This kind of antenna allows the use of direct match to 50 ohm coax and should not need a tuner and
will allow operation on mutibands with a little sweat equity on the construction side. Like I said in
preamble, read up on this one, might fit your yard and your radio needs.
Not going to spend much more time on multi band antennas because once you have narrowed your
focus as a newer ham you’re going to want to be louder than the guys using them, so next, a little time
will be devoted to how to double your power out and increase that skip distance thing you memorized
on your test!
Oh yeah; I GUARANTEE that either of the above antennas will work as well as or better than anything
sold commercially for 10 times the price!
AND; I am aware it is a short list, counting on my antenna gurus reading this to jump in and expand!
But before someone else points out the obvious , let it be known that almost any piece of wire will get
you on the air and be heard somewhere, but with a little homework you will enjoy designing something
to fit in your backyard that will expand your horizons. During WW2 a little toy called a Slinky, yeah that
thing, was used to successfully communicate on the battlefield! And hula hoops became super magnetic
loops able to work the world at will, just kidding about that one.
SO YOU WANT TO BE LOUD WAY OUT THERE?
Well that’s going to take a little work if you are willing to play with some wire.
On the upper bands pretty much everyone has a commercial, expensive beam on some sort, on a
tower, not to worry, the same can be done at nominal cost with wire. On 40 and below a wire gain
antenna is the way to go and not hard to do. And once you get a little more into phased reversible wire
arrays you will be truly competitive with most of the tower/ commercial store bought beam guys on ANY
band.
1: YE GOOD OLD DIPOLE!
The most efficient, easy to build mono band antenna out there. Unless you are getting creamed in
some contest with the big guns firing up their $20,000 stations, you will be heard, HOW?; because by
hook or crook you figured out a way to get that sucker up in the air at around ½ WL on the band of your
choice! If DX is your new found interest then broadside it to the NE/SW
If tight for room or lack of supports an inverted vee up as high as possible will give good results also.
Build your own and you will be amazed on any band with a dipole, especially with the emerging
sunspots. The secret to DX is the lowering of your take off angle into the ionosphere and getting that
first skip into the, direction/ area you’re chasing, a good high dipole can do it, other designs do it
better however.
2: WIRE GAIN ANTENNAS:
It is beyond the scope of this article to explain the intricacies of multi element beam antennas like the
one way up there on your neighbor’s tower.
Wire beams are relatively simple to build and extremely cheap! Commercial aluminum beams for any
band are based on the property of the dipole.
By adding some correct length and spaced wires in front of, or behind, or both, of a dipole you have
now focused the antenna in a narrower direction, another way to define gain.
Think of a flashlight as opposed to a candle and you will get the jist of focused energy in a specific
direction.
Simple Two Element Wire Beam:
For shape reference only.
The addition of one wire 5% longer behind a dipole in the same plain will give you 3dbd of gain, in
other words double your ERP; effective radiated power.
So that new 400 watt amp you saved up for will now have 800 watts going into the ionosphere. Oh yeah
the extra power out works on receive also, adding an additional S unit and better signal to noise ratio
for your hearing pleasure! You are focusing your transmitted signal in a smaller slice of the compass,
helping diminish annoying signals off the side and the back.
This concept is applicable for every band from 2 meters to 160 meters; the spacing and between the
two elements is subject to many variables and worth studying as is the possible shapes, quads, yagi,
quagi etc.
The usual spacing between the wires for most gain is around .15WL.
If you have successfully built a dipole and remember the formula of 468/freq to achieve your ½ wl wire
you are well on your way to using a little high school algebra to build your first beam antenna.
This process of free gain will open up an incredible arena of potential projects that will only be limited
by your imagination and your commitment to studying the immutable laws of physics often contrary to
a good portion of the advertisements we are all bombarded with everywhere.
Another worthy wire design is called a MOXON antenna with folded in elements that will fit where some
wire beams will not. The moxon is a fun antenna and worth some serious study if you are plagued by
loud stations behind you as it has very good front to back, meaning you will have an easier time hearing
the station you are looking at.
Single Wire Gain Antennas:
About the only true single wire antenna that has 3db gain over a dipole is an EDZ, extended double
zepp. These can be really long but if you have the room and tall enough supports this antenna will give
you the same gain as a two element beam in two opposite directions. Mine has been up for years and
has proven itself as the best narrow beam width single wire I have tried. Collinear antennas are a little
shorter but have less gain so I stick with the EDZ.
Point being, as a new amateur either one might fit your needs so it’s worth the homework.
Getting Up In The Air:
The higher the band the smaller the antenna, nice little piece of physical law.
Consider a 2 meter or a 10 meter wire beam built on the principals described above.
Small enough to build and hang from any available tree and leave a string hanging from one corner to
change directions, remember you built a directional beam, primitive maybe but mucho times
better than the stub on your 2 meter hand held.
NO TREES ? Try something like below:
For an inverted vee or center of a dipole an easy to get 40 ft in the air pole for $50 is pictured. I use
these things all the time in beam and vertical experiments They are 25ft extended and attached to a
2x4 and then to post holed 4x4, no concrete or help needed to install alone. Check fiberglass flag poles
or Spider poles.
SUMMARY:
I suggest the best thing for a newly licensed ham to do is to get on the air and start chatting with
people. You can ask them what antenna they are using and make your own deductions. Join a WAS net,
like CCN or OMISS and see what you like or dislike about your present antenna. Determine if you have a
favorite band that fits your interest and maybe upgrade to a mono band wire beam.
This article is a very cursory look at starter antennas and methods that will work great without killing
your checkbook.
Once you start down the road of designing and building your own antennas you will be addicted to this
very important facet of our hobby and who knows, maybe you will writing a better article in the near
future!
Tnx for reading,
N4JTE
by K2BEW on December 30, 2011
Mail this to a friend!
Now that is an article!
I am just getting on the HF bands this coming year and planning my antenna for my new qth and was thinking about trying to put up my own wires, now you have convinced me.
Question, with your fiberglass mast is it guyed and how does it hold up? I was trying to come up with something non-conductive (so I could feed it with a balanced ladder line) but not sure how this would hold up at that height. (35-40ft)
Thanks and 73,
Tom
N2BEW
by KD8GEH on December 30, 2011
Nice informative article Bob!
I was wondering what you were up to the other nite :) Keep up the good work.
73 DE Dave KD8GEH
by KC5EZ on December 30, 2011
Another good support is 3 2X4's. Two are bolted together with the 3rd in the middle. Now you have a hinge to raise the antenna. Painted or not, depends on your weather. Ten foot 2X4's = 20 ft. mast, 16 ft 2X4's = 32ft, etc. Used myself for fan dipole.
by KC8ZEV on December 30, 2011
I very much enjoyed the "thrifty" angle that was spun in the article. So many times, new hams come into the shop with $$ in their eyes and spend it on a rig without any consideration to the antenna. Should be the other way around! Some newbies, I won't sell them a rig until they go back home and devise an antenna system.....size, length, where it enters the shack, ground placement, power access in the shack, etc. and, no, I don't work on commission. So many think you need a massive tower, amplifier, giant beam and Bob Heil's custom line microphones and a 7800 to be a real station. I guess I have to give credit to marketing departments, their advertisements are working to some degree. But when there is a echo coming from a hams wallet, do not despair! Start with a dipole and then find a rig......that is what I did and my Trusty Icom 718 still serves me very well to this day. Sure there are better rigs out there, but I can still afford to be married and support the family.....something that comes up in divorce proceedings from time to time with hams.
KC8ZEV
by KB2DHG on December 30, 2011
TRULY A GREAT ARTICLE!
I think that wire antennas are the best bang for the buck and let me add, DON'T BUY THEM BUILD THEM...
I built my G5RV for a quarter of the price of a factory made one and it works MUCH better... I know this because I purchased a factory built one and it did not work as good as my home built one... I also reccomend using bear copper clad stranded wire not insulated wire...
Well, thanks for this great article... It was truly good information for the rookee...
by W9CLL on December 30, 2011
Excellent article!
I just passed my General but have been working 10 meters as a Tech for a bit before. Made a 10 meter inverted V that I have worked the world on. I am now going to hopefully this weekend add some wire to it for 15 and 20.
Thanks again
Chris W9CLL
by N6JSX on December 30, 2011
I'm partial to multi-band/element Inverted V as my general purpose all band HF antenna. Easy, cheap and very durable to make!
See eHam article "Antenna Spreaders" 03/2008.
If the Inverted V legs are ~120degrees (50ohm reactance) you can directly connect 50ohm coax - no balun required. A multi-band/element inverted V is the cheapest all around antenna you can build - plus it is one of the most effective antennas you can make.
Eventually you will try others and spend much putting in much effort to find a better multi-band antenna. Some may be better for your location but I bet you will return to the simple/cheap Inverted V.
by KK4DHD on December 30, 2011
Great article!!! However, you neglected to comment on what I really need to know: what type of antenna would be good for us new Generals who are HOA restricted? I'm just starting to assembly my HF kit, but will have to stash an antenna in my attic. What's type should I be looking at?
RE: Where Do I Go from Here?
by VE3FMC on December 30, 2011
What you put in your attic depends on the size and height of the attic.
Simple to tune wire dipoles are the easiest and likely the most efficient way to go.
You can put a fan dipole in your attic which will allow you to cover different bands. Remember this, you can bend the ends of the dipoles if you do not have room to stretch them out straight.
So depending on the size of your attic you could possibly put a 40 through 10 meter fan dipole up there if you can get the elements spaced out.
Another option would be one of the multiband aluminum dipoles like the Cushcraft D-3 which totals just over 25 feet in length.
However you can build the same beast with wire at a fraction of the cost.
Google Ham Radio Attic Antennas and you will find a wealth of knowledge.
And yes attic dipoles work, I would be willing to bet there is more than one member of this forum using them.
by W2LJ on December 30, 2011
Bob, excellent article ..... and "rolling your own" is always a nice way to go.
May I suggest a link?
http://www.ve3sqb.com/hamaerials/w1gfh/
I used a variation of this for years with great success.
Happy New Year, everybody!
73 de Larry W2LJ
by N4JTE on December 30, 2011
Thank you Clint, article manager, for getting this posted as written, big tnx and great job!
by ND8F on December 30, 2011
Mr Bob, N4JTE
As always, you have another great article. I don't usually respond to these, but this one is really GREAT. Hopefully some of your vast amount of experience that you are sharing here will assist someone. Great job My Friend
by N9AOP on December 30, 2011
Back in the day I just layed out a long wire. Didn't know about counterpoises or swr, just loaded it and went. The novice bands were wall to wall signals at certain times of the day and contacts were easy and exciting. Later I used a trap dipole which was common back then. Didn't cost much because it was someones hand me down. Seemed like there were more Elmers around back then also.
Art
by KG4NEL on December 30, 2011
What I wouldn't mind seeing are more options out there for building your own ladder line - I've been thinking about putting up a 130ft+ doublet in the spring, and I'd like to use wider line than the 450-ohm stuff to lessen the effects of rain.
I tend to be lazy, so when I put up a wire antenna I don't want to think about replacing it for a *long* time :P
by K7EDL on December 30, 2011
Great article, the first rule is get something up. My first antenna at a temporary qth with out trees was a 20 meter vertical hung from a wire attached to a expanding paint pole which was duct taped to a step ladder. the vertical portion was cut from speaker wire from a home stereo. the radials were cut from phone wire there were four of them because there are four wires inside phone wire. These were attached to pop bottles filled with water which held them out at an angle on the lawn. When the landlord wanted to mow the grass the whole thing rolled up in less than 10 minutes and it went back up just as fast. I worked all over the pacific last summer and enjoyed every minute of it. with my antenna tuner It worked 10,15,17 and 20 I fed it with radio shack coax it fit my budget. when I get a few more dollars I will get some real coax but at least I am on the air and geting good reports.
Eric K7EDL (my new call)
by N5UD on December 31, 2011
Good article.
My first HF antenna was a 40M inverted vee. A long cane pole was the support. It was attached to vent pipe on the roof of the house. I also used it on 15M.
Next were some cubical quads. They were made with cane poles and lumber.
73 Tony N5UD
by W3JAR on December 31, 2011
Thanks for the great article! It is nice to know that you don't need tons of cash to work around the world. I have been a ham since last October. The first year I was limited to VHF with my ft60. Just bought an ic706 this September and have been trying to get on hf for several months. Started with a 66 ft dipole. One end hanging out my window and the other half running through my tiny NYC apartment. NO LUCK!
Right now, a genius ham has been woking with me to help design a new antenna in hopes offending on hf. Looks like all you need is some wire and some friends and life is good!
John
by K9ARM on December 31, 2011
Great article Bob!
I built a 132' dipole fed with 450 ohm ladder line and later changed it to 4" spaced open-wire line. It works great and easily covers 80-10 with a Ten-Tec tuner.
Here are 3 sources for open wire line, I built the second because
I had most of the parts on hand. There may be other sources.
http://www.trueladderline.com/
http://www.youtube.com/watch?v=qzFKGB6qkXs
http://www.73cnc.com/product_p/ls100.htm
Also, look at Walter Maxwell's Refelctions book and his discussion on SWR, conjugate matching, etc. You can view some of the chapters on his site:
http://w2du.com/
Andy K9ARM
by W8KQE on December 31, 2011
There are many decent choices one can make in order to get effective multiband coverage without the cost of towers and full size yagis. 'Mosley' makes lightweight 'junior' type beams/yagis (like the TA-32 Junior or TA-33 Junior) that can be mounted on a medium to large sized house chimney or tripod, and turned by lesser cost rotors. You can add 12 and 17 meter 'add on kits' to these as well, giving you 5 band coverage and directionality. A bargain in my book!
by M0DRH on December 31, 2011
Nice Article, and a "KISS" approach :)
I have been active/in-active for many years.
Now (since Feb 2011) been active again at new QTH.
I threw together a wire Fan Dipole for 17/10/6M, favorite bands.
It is at the amzing height of approx 3M or 10'.
It's amazing what you can do with a bit of perseverance/skill?
I have limited time to operate, so only 360 entries in the log in 10 months.
I spend 90% listening/tuning then pounce.
But have been rewarded with:
17M 78 DXCC's and 36 WAS
10M 96 DXCC's and 48 WAS, only need MT & HI (I have heard them)
6M not really much logged.
So simple also works for me :)
Just build, try it, have fun.
Best 73 & Good DX
Happy New Year
Dave
by W8BRI on December 31, 2011
Very nice article. one of the best I've seen here.
Brian w8bri
by N4JTE on December 31, 2011
Thank you Homer, I sincerely hope a new ham makes a contact with you, you exemplify the spirit of ham radio and you know how to make first timers comfortable. The true spirit of ham radio!
by KJ4NOO on December 31, 2011
Simple wire antennas work great at low cost. I have worked a lot of DX with a G5RV before I built my hex beam. Learning is part of the fun for me.
by G3LBS on January 1, 2012
The best bargain is 100ft of 300 ohm twin line from RadioShack for about 15 dollars. Next best is homebrew cubical quad - high gain and front-to-back, wide bandwidth, light weight. See eHam Product Reviews.
by W4VR on January 1, 2012
Kudos to you Mr. Bob. First I would like to say "congrats" on finally marrying that great lady friend that's been supporting your hobby with devout respect for the past 10 years. I also want to congratulate you on your excellent articles about antennas that require zero towers. If you don't have trees, put up a pole...for some darn reason many hams don't think about doing the pole thing. Have you ever thought about writing a book about this stuff?
by XE1GXG on January 2, 2012
Good, basic tips! I recommend "Practical and Tested Aerial Systems" by Keyser, Ian G3R00 (Fishpool,Tony G4WIF, ed.) And the ARRL Antenna Book. 73
by K6CRC on January 2, 2012
New hams should also look at the PAR end fed antennas. They are easy to install in areas where you do not have the room to feed from the center of a wire antenna.
by N4KC on January 3, 2012
I'll join in the "great article" pile-on! We old-timers forget what a formidable task it is to new hams to contemplate antenna possibilities.
On the one hand, they are excited, ready to get on the air, but with limited knowledge of what to do to get going. Then, on the other hand, they have spouses, neighbors, Mother Nature, HOAs and plenty of other obstacles in their paths to ham happiness.
Think back. Put yourself in their place, just as YOU were XX years ago. Don't put them down because they don't know it all already. Neither did you. Don't suggest exotic aerials, multi-element phased arrays, or stacked quads on towering towers. Help 'em get on the air with something that will 1) Show them the thrill of communication, and 2) Whet the appetite to learn more about the amazing realm of antennas.
Bob has done a good job of both here. I did a similar article here on eHam a while back:
http://www.eham.net/articles/21270
Welcome, newcomers to HF...and we'll "see you on the wind!"
Don Keith N4KC
www.n4kc.com
www.donkeith.com
http://n4kc.blogspot.com
by KH6JRM on January 3, 2012
Good article, Bob. I've used homebrew inverted vees and verticals for years. Like many of my fellow hams, I live in a crowded neighborhood with power lines, weak TV reception, and limited space. My backyard antenna "farm" consists of a 40-meter inverted vee and a 20-meter vertical dipole. Both are fed with 450-ohm ladder line into a 4:1 balun and then RG-8 into my trusty Drake MN-4. I also have a full wavelength 40-meter loop under the house (the qth is on an elevated post and pier system). This NVIS antenna does great on nets around the Hawaiian Islands. Don't be afraid to experiment...that's half the fun of amateur radio. I'm having a ball at a minimum cost. When you reach the retirement zone as I have, every penny counts. Aloha, Russ
by K5WCF on January 4, 2012
Well, I think the replies speak volumes about this article. I really wish more people would convey this information to new hams. I remember when I finally got my HF rig, a brand new FT-897D and the last thing I wanted to do was hook up a questionable antenna and mess up my transceiver. Not to mention I had already spent a fortune on my rig and tuner, and did not want to spend the same on an antenna. Most of the locals were quick to say build a double bazooka, but even that doesn't come cheap. so luckily I found a great write up on a basic wire dipole that was super cheap and guess what it works great just hanging up in a tree. The best part was I spent all of about 30 dollars to build it. just remember it's ok to keep it simple stupid.
by NZ5L on January 6, 2012
Excellent article, comprehensive and well illustrated.
On the subject of the EDZ dipole (which is, in fact a type of "colinear" antenna) there is a worthwhile alternative. This is called the "High Gain Single Wire", or HGSW, antenna. It is bi-directional like the EDZ and about 25% longer than an EDZ and uses ladder line stubs for proper phasing of elements. I have had mine up (at only 22') for the 17Meter band for two years now and am always amazed at the DX results with 100W. The article appeared in July 09 QST. Different feeder techniques are possible, and a ladder line fed version gives multi band operation, although only giving its stated gain on the design band. Worth the trouble if you have the space.
by N4JTE on January 6, 2012
Thank you all, appreciate all the added ideas for a new ham venturing into real antennas that will work.
Great job.
by KDMSKY59 on January 7, 2012
Vertical end fed half wave tuned at the feedpoint with coax to the shack.
Best single band wire antenna.
by K1DA on January 11, 2012
This article about covers it. Just like to add that it is generally better to clamp window and ladder line between plexi sheets at the center than to hang it from a dog bone. Clamp the feedline and solder a piece of 16 or 18 gauge stranded from the line ends to the antenna wires The copperweld wire used for the ladder line is subject to failure when flexed. You don't need a "brand name 'Signal Zorcher 5000'" dipole, but take a good look at a few to see how the mechanics are done before you make your own.
by K6SGH on January 14, 2012
Build a MOXON antenna. The cheapest best antenna you can ever build. http://www.moxonantennaproject.com .
Hams all over the world love this simple and very effective antenna.
--k6sgh
by K0KNX on January 15, 2012
Ladder line is the best way to displease your XYL, HOA Nazi's and Neighbors...it may be a little more efficient but to most, it's a horrible eyesore.
by KC5PIE on January 15, 2012
Listening in on a Realistic DX-300 that I bought at the Belton ham-fest for $30.00.. Antenna is a random wire slung into the tallest tree in the backyard. HF never sounded so good!
Gotta love a simple wire antenna..
73 de kc5pie
by ASA on January 20, 2012
Hello,
You might consider an inverted L end fed antenna. Mine works great on 20/40 meters. I also have a Gap Titian vertical (no radials required) painted green, mounted on tilt stand (tropical storms in Florida), hidden next to bamboo trees in the corner of my lot. I installed an antenna in the attic of my two story house with poor results. I would recommend doing whatever you can to install your antenna outside.
Steve
KJ4OWK
End fed link:
www.LnRprecision.com
by KE7GZF on January 21, 2012
You are so right you have to think of your XYL, you need to give them some your time also. I found out if you want to keep piece in the family you need to give them some your time. I now only go on the air at least once a week on a net with guys that I used to work with.
73 Ernie
by HB9CPS on January 25, 2012
Great article!
With this kind of antennas you can easily achieve DXCC, break pileups and win contests - the heavy iron full power big gun will be certainly ahead of you, but your satisfaction will be as good as his...
73, geo
by W5XJ on January 31, 2012
Some great ideas. If you have the funds, I like using a remote autotuner (MFJ, SGC, ICOM AH-4, etc) at the feedpoint of a vertical , long dipole or square loop. This saves mismatch loss and RFI on the coax and works like a champ. Remote tuners new cost $200.00 or more so if your budget is tight find a used one. I found a used AH-4 at the Belton Hamfest and paid $50 for it. I use this tuner on campouts and portable with the S-9 31 foot vertical over a homebrew radial plate. This antenna is now sold by LDG since they bought out the S-9 fellow. Too bad they don't make a remote tuner - yet. This vertical with a remote tuner is a great way to get on the air for DX with a low angle of radiation if you don't have trees to use to pull wires up with. You could even put a small flag on it if need be. If you use the vertical remember that you have to make up the other half of the antenna so to speak on the ground. A vertical without radials won't work well so do it right an reap the benefits. You can skip the S-9 for a setup at home by running a long wire as an inverted " L ".
Good luck and good DX de W5XJ!
What Do You Want Your Antenna to Do?
How I Got Introduced to Amateur Radio
The [Wire] Antenna Builders Survival Guide
