Amateurs Must Protect New Radars in 23 cm Band:
from The ARRL Letter on April 13, 2012
The Federal Aviation Administration (FAA http://www.faa.gov/) is deploying a new generation of Common Air Route Surveillance Radar (CARSR) that has some implications for the use of the 1240-1300 MHz (23 cm) band by amateurs. The Amateur Service allocation in this band is on a secondary basis, with aeronautical radionavigation and several other services primary in the United States Table of Frequency Allocations. The FCC rules require that amateur stations operating in the 23 cm band may not cause harmful interference to stations in the radionavigation-satellite service, the aeronautical radionavigation service, the Earth exploration-satellite service (active) or the space research service (active). One case of harmful interference in Southern California has been reported.
CARSRs are being installed in several dozen locations throughout the country and will use various frequencies in the 1240-1350 MHz range with an occupied bandwidth of about 3 MHz. In the vicinity of the radars, amateur operation may be precluded in a portion of the 23 cm band. The ARRL is in contact with FAA engineers. We anticipate that the constraints on amateur use of the band will be limited to those necessary to protect aviation safety, which of course cannot be compromised.
Just Ahead in Radiosport:
ARRL National Centennial Convention Kicks Off Ham Radio's Second Century:
Convention Provides Springboard for 'Amateur Radio Parity Act, 'HR.4969:
FEMA, ARRL Sign Agreement; FEMA Administrator Calls Ham Radio 'Resilient':
