Propagation Forecast Bulletin #32 de K7RA:
from W1AW Bulletin via the ARRL on August 10, 2012
ZCZC AP33
Propagation Forecast Bulletin 32 ARLP032
>From Tad Cook, K7RA
Seattle, WA August 10, 2012
SB PROP ARL ARLP032
ARLP032 Propagation de K7RA
The bulletin today is coming from Eugene, Oregon.
Average daily sunspot numbers rose over 20 points this week, or about twenty-percent, to 119.4. The average daily solar flux was up 3 points to 134.7.
Geomagnetic activity was quiet, with unsettled conditions around August 2.
The NOAA/USAF prediction has solar flux at 135 on August 10, 130 on August 11-12, then 125, 120, and 115 on August 13-15, then 110 on August 16-17, then 95 on August 18, 100 on August 19-20, then 110, 115, 120, 125, 130, 135, 140 and 145 on August 21-28, then 140 on August 29-31.
Predicted planetary A index is 5, 8 and 10 on August 10-12, then 5 on August 13-15, then 10, 8, 5, 8 and 8 on August 16-20, then 5 on August 21-23, and 8 on August 24-25, then 12 on August 26, then 5 on August 27 through September 14.
F.K. Janda, OK1HH sees quiet geomagnetic conditions on August 10, mostly quiet August 11, active to disturbed August 12, quiet to active August 13, mostly quiet on August 14, quiet August 15-16, quiet to unsettled August 17-20, mostly quiet August 21, quiet August 22-24, quiet to active August 25-26, mostly quiet August 27-28, active to disturbed again August 29-30, and a return to quiet on August 31 through September 1.
Check out some nice solar images at http://blogs.discovermagazine.com/badastronomy/2012/08/09/the-sun-is-shagadelic-baby/ and http://www.space.com/17003-sun-eruption-solar-filament-video.html.
O.J. Lougheed, AD7DR of Lopez Island, Washington wrote: "I've been interested in transpolar propagation since I lived in Irkutsk, Siberia from 1997-2004. I'm thinking of putting together a ham club at the school on Lopez Island and your name popped up with an internet search. There is so little on the web. With sunspots picking up, things (I would assume) will get exciting. Do you know of any EU or Russian/Ukrainian folks interested in such propagation?"
I don't know, but if any readers across the poles or anywhere want to contact AD7DR, look him up in QRZ.com, where you will find his email address. You will have to login, but getting an account is free.
Larry Godek, W0OGH of Gilbert, Arizona wrote on Thursday, August 9, "Spratly Island, 9M4SLL has been worked on both 20 meter SSB and CW, along with CW on 15, with great signals.
Comoros Islands, D64K was worked on 15 yesterday at 2155Z. Had good signals into this area all the time he was on the air. Typically shortly after I get to work them, the band goes out. Happens a lot to me on 20 as well. Just like Arizona is the last place to make a QSO even though I hear the DX for long periods of time.
ZS2I was worked this morning at 1353Z on 20 CW long path. He couldn't hear me on the regular path so turned the antenna around to 270 degrees and he came up to over S9.
Talk about short hop, J68HZ was worked yesterday at 2224Z on 28.375. He was working mainly 4-land and the east coast. Surprised he came back to me.
Same thing with HT9H on 18.073 MHz at 2215Z. But then we had a large storm front within 100 miles from the north around thru the east to the SE. Then 20 this morning has been excellent to the Pacific.
Yesterday in the morning we had a 6 meter opening, double hop into Florida, Tennessee, South Carolina and Texas. Nothing unusual about the Texas stations as the area from EM00 though EM03 and EM10 thru EM13 are the first hop for us. They usually have loud signals and are typically the first stations from the E we hear.
There would be an idea. If it were possible, have any DX station, maybe some of the rarer types, run a WSPR beacon. If they can capture your signal at 2W, then you've got a path. But then there is a lot of one way propagation that goes on isn't there?
Really been a pretty fair year so far for DX. 30 meters has been a disappointment as has 10. If it wasn't for 15 and 20 there would be very little DX.
We print all the ARRL bulletins on a Model 28 TTY machine here. Everything that is 45 Baud 60WPM anyway. Really nice that ARRL continues that mode. Lots of hams around the country have real mechanical TTY machines and look forward to running them several times a week. Keeps the oil and grease from getting old, kinda like the body!"
Burton Boyd, W7IIT of Bremerton, Washington says his hearing isn't as sharp as it used to be, and he can't always hear the WWV broadcasts of geophysical data at 18 minutes after each hour. I advised Burt to get the info off the internet at http://www.swpc.noaa.gov/ftpdir/latest/wwv.txt.
For more information concerning radio propagation, see the ARRL Technical Information Service at http://arrl.org/propagation-of-rf-signals. For an explanation of the numbers used in this bulletin, see http://arrl.org/the-sun-the-earth-the-ionosphere. An archive of past propagation bulletins is at http://arrl.org/w1aw-bulletins-archive-propagation. Find more good information and tutorials on propagation at http://myplace.frontier.com/~k9la/.
Sunspot numbers for August 2 through 8 were 126, 160, 140, 107, 108, 96, and 99, with a mean of 119.4. 10.7 cm flux was 134.6, 139.7, 138.7, 134, 134.1, 128.5, and 133.3, with a mean of 134.7. Estimated planetary A indices were 16, 7, 7, 6, 11, 7, and 10, with a mean of 9.1. Estimated mid-latitude A indices were 16, 8, 6, 6, 10, 8, and 12 with a mean of 9.4.
Weather Service to Offer Skywarn Training in Mount Morris:
RSGB: Spectrum Release:
Solar Activity on the Rise:
Israeli Amateurs on 5 MHz:
WIA Submission to ACMA on High Power Trial:
