Top Off the Years on Top Band in the ARRL 160 Meter Contest:
from The ARRL Letter on November 21, 2012
While Solar Cycle 24 is making the high bands the focal point for HF operators, 160 meters -- Top Band -- is still chock full of DX. There's no better time to get on 160 meters than the ARRL 160 Meter Contest http://www.arrl.org/160-meter, November 30-December 2.
The ARRL 160 Meter Contest is an all-CW event, with ARRL/RAC Sections and DXCC entities used as multipliers. If you live in a rare Section -- such as North Dakota, Nebraska or any of the rare Sections from the November Sweepstakes contests -- everyone will be seeking you. Hams in Ontario (VE3) will have a new role in this year's contest: The split of Ontario into four new sections -- Ontario East (ONE), Ontario North (ONN), Ontario South (ONS) and the Greater Toronto Area (GTA) -- will give everybody a few new multipliers to hunt for on Top Band.
In this contest, Alaska (KL7) and Hawaii (KH6) can be worked by both DX and US/Canadian stations, as can the Caribbean US possessions (KP1-KP5) and all of the Pacific Ocean territories (KH0-KH9). No antennas for 160? Don't be discouraged! According to ARRL Contest Branch Manager Sean Kutzko, KX9X, if you don't have an antenna for 160, put up a temporary length of wire or try to load up whatever you have through an antenna tuner; even a 40 meter dipole through a tuner will make some QSOs.
Since ARRL and RAC Sections are worth 2 points each and count as multipliers, the ARRL 160 Meter Contest is a good way to begin working -- or finishing up! -- your Worked All States Award (WAS http://www.arrl.org/was). But don't forget about those DX stations -- each DXCC entity is a multiplier and is worth 5 points.
The 2012 ARRL 160 Meter Contest http://www.arrl.org/160-meter runs from 2200 UTC Friday, November 30 through 1559 UTC Sunday, December 2. Complete rules and entry forms may be found here http://www.arrl.org/contests. Logs must be e-mailed 160meter@arrl.org or postmarked no later than 1600 UTC Tuesday, January 1, 2013. Paper logs should be sent to ARRL 160 Meter Contest, 225 Main St, Newington, CT 06111.
