Ham Radio Club will Celebrate 40th Anniversary:
Alliston Historical Society Learns About Early Days of Radio:
Foundations of Amateur Radio -- #94:
VK6WIA -- NewsWest for 26 March, 2017:
Sunnyvale Ham Radio Outlet Closes After 26 Years:
