A Visit to ARRL Headquarters:
FCC Denies Petition for Amateur Radio Assignment Inside TV Channel 4:
FCC Commissioner: Repurpose 400 MHz Range:
Amateur Radio -- In Times of Trouble or Just for Fun:
Ham Radio Operator Objects To Anti-Texting RADAR:
