If the amplifiers are linear and can amplify at very low levels, it would be drive them with an input splitter and measure the power at each output. If they are the same and you put them in a combiner and the level is twice each, less the attenuation of the combiner, you are probably good to go. I would bring up the power slowly and watch for heating and other undesired effects.
Thanks Doctor! Do you have a question or a problem? Send your questions via e-mail or to "The Doctor," ARRL, 225 Main St, Newington, CT 06111 (no phone calls, please). Look for "The Doctor Is In" every month in QST, the official journal of the ARRL.
