Boy Scouts Get Their Hands On 'Ham' Radio in Cheltenham:
Water District OKs Ham Repeater:
Propagation Forecast Bulletin #44 de K7RA:
Ham Radio Operators Ready for 'Nilofar':
Strange Radio Signals Detected from Ancient Underwater Building Near Malibu
