Ham Radio Clubs in IITs, NITs Could Boost Emergency Communications:
Volunteer Connection: Amateur Radio -- a Key Component of Disaster Response
How You Can Talk to an Astronaut from Home:
Propagation Forecast Bulletin #39 de K7RA:
Oak Ridge 'Hams' Show Children Fun of Amateur Radio at Children’s Museum:
