Propagation Forecast Bulletin #22 de K7RA:
Hams Invited to Test APRS on Duchifat-1 CubeSat:
Public Demo of Emergency Communications June 27:
Desert Wave Amateur Radio Club Donates Ham Radio License Manuals:
'Hams' to Make International Connections at Camdenton Event:
