The Australian Communications and Media Authority (ACMA has ended an 18-month trial that allowed participating Advanced licensees in that country to run up to 1 kW on the HF bands. Advanced licensees Down Under are limited to 400 W PEP. ACMA reached its decision earlier this month following a detailed assessment begun last March.
"Of the 297 that did obtain the authorization, the ACMA was advised by some participants that they had not used higher power," the agency said in its decision. ACMA said participant comments it received via the Wireless Institute of Australia (WIA indicated that the benefits of running higher power "were confined to those respondents and do not demonstrate broader benefits to the wider community."
The WIA for some time has been pushing for higher power limits for Advanced licensees, who feel the current 400 W power limit puts them at a disadvantage, especially in contests, while other countries permit 1 kW or more. After the New Zealand Amateur Radio Transmitters (NZART was able to convince regulators in that country to raise the power limit on similar grounds, the WIA was encouraged to again pursue the matter. After the WIA was informed of ACMA's decision to end the trial, and, following talks, it was decided that the ACMA would revisit the issue next year. -- ACMA, WIA, Jim Linton VK3PC
Ham It Up -- In an Educational Way, of Course:
Old Technology Could Prove Valuable:
Propagation Forecast Bulletin #41 de K7RA:
Fox-1A is Now AO-85, Transponder Temporarily Active!
Hiram Percy Maxim Grave Location
