ZCZC AG32
ARRL Bulletin 32 ARLB032
>From ARRL Headquarters
Newington CT December 2, 2013
SB QST ARL ARLB032
Raven Hill Discovery Center's Ham Radio Station Up and Running:
Radio Amateurs Get Practical Thank You for Tour de France Backup:
5-Year-Old Passes Ham Radio Exam:
First Light / EME to Follow:
Emergency Management Seeks Communications Grant:
