ZCZC AG32
ARRL Bulletin 32 ARLB032
>From ARRL Headquarters
Newington CT December 2, 2013
SB QST ARL ARLB032
FCC Commissioner: Repurpose 400 MHz Range:
Amateur Radio -- In Times of Trouble or Just for Fun:
Ham Radio Operator Objects To Anti-Texting RADAR:
Isabella Hosted Annual, 24-Hour Amateur Radio Field Day Event:
