ADDRESS BINARY HEX
___________________________
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
  2: FT817OS Basic Usage
Amateur Radio Operators Reach Out to World:
More Memories of Wartime Life as a Morse Code Operator:
Mobile App Radio Transceiver Enabling Over 500 Users Communication:
Telegraph Club Keeps Once-Revolutionary Technology Alive:
FCC Comments Urge Allocation of Spectrum Above 24 GHz for 5G And More:
