ADDRESS BINARY HEX
___________________________
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
  2: FT817OS Basic Usage
FCC Issues K3VR $11,500 NAL:
India's VO-52 Satellite Goes Dark:
Hams and Uncle Sam Grow Closer:
FCC Issues KZ8O $22,000 NAL:
The Inaugural Victorian D-Star Users Group Meeting:
