ADDRESS BINARY HEX
___________________________
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
  2: FT817OS Basic Usage
Sun Unleashes Powerful X-Class Solar Flare:
Ham Radio Groups Tapped as Extra Eyes, Ears for PNP:
ARNewsline Report 1941 -- Oct 24 2014:
