ADDRESS BINARY HEX
___________________________
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
  2: FT817OS Basic Usage
Squawking Ham Radios and Adventure Race Repeaters:
Ham Radio Buffs in Blaine Dedicate Themselves to Community Service:
Many Attend Amateur Radio Operator Event:
Ham Radio Club Sees Antenna Towers:
FCC Seeks Comments on Waiver Request from Expert Linears:
