ADDRESS BINARY HEX
___________________________
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
  2: FT817OS Basic Usage
ARTSAT2: DESPATCH Satellite is Now FO-81:
New Element 3 (General Class) Question Pool Released:
Just Ahead In Radiosport:
'Amateur Radio Parity Act' Campaign Will Resume In New Congress:
