ADDRESS BINARY HEX
___________________________
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
  2: FT817OS Basic Usage
Ham Radio Keeps Campbell On the Move:
When Disaster Strikes, There May Not Be an App for That:
Why Morse Code is Actually a Really Weird Way to Communicate:
Sun Eruptions Hit Earth like a 'Sneeze', Say Scientists:
