One thing I need is for everyone to type into FT817OS (without quotes) 'get config' and let me know in an email at
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
The link to the module on CPAN is
Information on installing Perl Modules can be found at l
  2: FT817OS Basic Usage
Foundations of Amateur Radio -- Episode 73:
Ham Radio Contest and Strategy:
Learning Morse Code Without Trying:
STEREO -- 10 Years of Revolutionary Solar Views:
