ADDRESS BINARY HEX
___________________________
0x04 11001110 ce
0x05 10111111 bf
2. what country you are in
  2: FT817OS Basic Usage
Augusta Amateur Radio Association to Host WinterFest:
New Section Manager Appointed in West Virginia:
VK6WIA -- NewsWest, 26 February 2017:
Amateur Radio Newsline™ Report 2052 for Friday, February 24, 2017:
