Excellent Video from the ISS:
'Base to Hams: Field Day this Weekend . . . Over':
FCC Invites Comments on ARRL Petition to Allocate New 5 MHz Band:
New Section Manager Appointed in Illinois:
ARISS Opens Window for Proposals to Host Contacts with Space Station Crew:
