Scouts Learn About Amateur Radio at JOTA Event:
Amateur Radio Operators Ready to Ham It Up in Maricopa:
Ham Radio: Definition, Origins, Goals:
DX News -- ARRL DX Bulletin #43:
Georgia Section Manager Changing on November 1:
