New Satellites on the Horizon:
Marshall Islands and Amelia Earhart SOS's Recreation:
Foundations of Amateur Radio -- #79:
Propagation Forecast Bulletin #50 de K7RA:
Amateur Radio Newsline Report 2041, December 9 2016:
