Sun Unleashes Powerful X-Class Solar Flare:
Ham Radio Groups Tapped as Extra Eyes, Ears for PNP:
ARNewsline Report 1941 -- Oct 24 2014:
DX News -- ARRL DX Bulletin #43:
