Practical tips for home brewing
Henk Tobbe (VK2GWK) on June 10, 2002
Practical tips for home brewing.
Elsewhere on eHam I recently complained about the lack of technical articles. Hams cannot live on jokes alone.... But this immediately induced a guilty feeling as I realised I had done nothing about it but whine....
I am afraid I cannot offer you great wisdom or the project to build that will end all projects. You might even wonder about the language used in this article as English is not my native tongue. (I was born in PA country). But I think I have something to offer from long experience in home-brewing that might benefit newer hams that feel uncomfortable when they just plug in and play. Because in my very humble opinion a threat to ham radio , far greater than the CW issue, is the lack of interest in THE EXPERIMENT. By the way.... I do not have some sort of master's degree in electronics but was trained as lawyer and have been managing an insurance company for most of my life...
There are many occasions where a modern ham can benefit from some do it yourself. First, you save heaps of money. But even more importantly: making a QSO from a set up that - even as a minor part - contains something that you constructed yourself gives enormous satisfaction. Because when you know how the thing works that you made, you have the power over it and can change parameters and try to do even better! All the knobs and dials on your FTxxx or ICyyy only allow you so much and not more. But when you make something yourself you know you can change that resistor or capacitor and may be get more output, better signal to noise ratio or a higher gain.
Figure 1 - My shack
What do you need for this sort side of hamming... A really big junk box. A box, set of small containers, drawers, baskets and what have you with all sorts of components, bits and pieces, bolts, nuts, brackets and other unthinkables and unmentionables. Never throw away today what you might need tomorrow..... All circuit boards of old, obsolete or discarded equipment have something on them what you might need for your next experiment. I have not less then three shelves with containers in my shed with old boards, parts and equipment; some tens of years old. The other day I used a variable capacitor from one of the boxes of which I remembered that I it bought in a flea market some 40 years ago.....
Printed circuit boards can be easily stripped of components with one of these hot air guns to strip paint. Heat the solder side and knock the board to make the parts fall out. Amazing how many TLL and CMOS IC's survive this sort of abuse. Capacitors and resistors have short leads but are ideally sized for bread boarding or re-use on perf-board. Scavenging single components from a board usually requires desoldering litze of which I always have ample stock.
By the way: do the stripping outdoors.... The XYL (or OM to be Politically Correct) will object because of the smell and it is also healthier in the open air....
I also fill my junk box by selective buying at ham fairs and flee markets and (after dark) picking up the odd TV set, old computer or micro wave from the road side.... Res derelicta, the lawyers call that stuff.
You also need a breadboard and a versatile power supply. The power supply should have minimal 5 V, +12V and -12V at 1 - 3 Amp. So any old computer power supply will do. Decorate it with a voltmeter and/or mAmp meter. But without that it works just as well. I use a couple of old and cheap multimeters that I collected through the years. Lacking that... some component sellers have them for $10 - 15.... I have one of these older Heathkit breadboards cum power supply with built in sine and square wave generator up to 10 KHz. When you find one somewhere.... Buy immediately!
Figure 2- My breadboard
Other handy tools are a simple frequency counter (at least to 50 MC) and a signal generator (available in most flee markets). I also made a couple of marker generators from old crystals and Cmos dividers for various -exact - frequencies, like 1000 Hz, 1 MHz and so on. And of course a good - temperature controlled - soldering iron, various pliers and cutters and a set of screwdrivers and a bit set for taking things apart (and putting them together again - occasionally). Especially the tools make great presents for your birthday, Fathers/Mothers Day and Christmas. Things the XYL (or OM) or the kids can actually buy themselves and in secret without too much instructions and prompting from you.
The breadboard is handy to set up experiments with designs you may find in magazines or on the Internet. Before ordering the PC board just check out if it will work for you and do some experimenting and make some measurements. Sometimes the praised design is not so ideal after all....Use the stuff from your junk box and check out if you really need to buy that kit on offer or that you may have all the - slightly different - components in your junk box already. That makes it really interesting because it might even work better with the components you got.
Experimenting and copying designs for kits with components you already have, saves money and will eventually enable you to buy an oscilloscope instead of another ready made piece of simply reproducible electronics that other people market for profit. This is a really handy piece of gear, for signal tracing, fault finding, aligning and all other little jobs during an experiment. Dual trace, 20 MHz is affordable these days and will do unless you really go SHF...
After the breadboard testing I make most of my designs on Vero-board or - preferably - perf board with little copper islands and not with strips. Connections between components and IC sockets I make with wire wrap wire. Not wire wrapping but soldering. To strip the insulation of wire wrap wire use pliers and knick the end of the wire. The insulation will split and can be cut away with nail clippers. The result looks a bit like needlepoint and it needs the same sort of magnifying glass to do it neatly.
Figure 3 - like needlepoint - you need a magnifier...
Also try to build a library of books and data sheets for the most frequently used components. I have two very thumbed data books, one on semiconductors and one on TTL IC's. The last ten years I built a large favourites list of web sites with data and data sheets. For all the more specialised components in my collection I have the .PDF file with the data sheet and application notes stored in a special directory. Of course there should be an ARRL Handbook in every shack and a subscription to an electronics experimenters magazine keeps you up to date with developments.
When experimenting make copious notes of what you do, what changes you make and what the results of these changes are. This helps to find where you went wrong or why the circuit became smelly and started to smoke. That should not put you off.... It is all part of the experiment. Just grab a replacement part from your junk box and start again.
Recently I started to make digital pictures as well. Especially when repairing equipment while taking it apart. Make notes on a printed picture or make the notes with your favourite photo-drawing software. It is a great help when putting the thing together again afterwards and this way less nuts and bolts are left over....
Last but not least. have lots of patience. Do not expect something to work the first time. To get it right you really have to experiment. Use the multimeter to check if all voltages are where they should be. Measure across resistors to check wether active components draw the right current. Check your soldering for shorts, dry joints and so on. When you are at a dead end, give it a rest and do something else. Your sub conscious will keep at it and it'll come to you like a flash.
Also when mounting boards and other components in a cabinet - other than a prefab kit you bought - never rush things..... Have a good look through your junk box - that may give you an idea how to make the cabinet. I make a lot of cabinets from double sided epoxy PC board. Easy to work with (hacksaw and small drill). Can be soldered together and components like small switches can be soldered on. Ideal for front plates - glue a (colour) printed front on and it looks even professional.
Hope this inspires at least one person to take up his soldering iron and discover a fascinating side of our beloved hobby.
Henk - VK2GWK (ex PAoADC)
One Mile Beach NSW - Australia
by HOS on June 10, 2002 Mail this to a friend!
As a new HAM, (waiting to take the Tech test here) this is the kind of article that gets my jucies flowing! Also, an excuse not to throw away all those computers and parts that are cluttering up my work shop...
Thanks for the great article and keep them coming, maybe your favorite project...I'm browsing the Handbook just now looking for something to stick the soldering iron too...
Cheers,
by N8AUC on June 10, 2002 Mail this to a friend!
Henk,
Excellent advice for an aspiring homebrewer.
Your parts stash - well - they don't call it a
"junk box" for nothing!
There's nothing like the feeling of making a contact
with a rig you built yourself. It's just awesome!!!
73 de N8AUC
Eric
by JAVAP on June 11, 2002 Mail this to a friend!
I just decided to become a radio amateur last month. Eham.net has been a fantastic resource so far!
So how exactly does one get into home brewing? The study guides don't cover much on this subject. Is The ARRL Handbook is a little too much for a raw beginner?
What are other pieces of required reading on the art of homebrewing?
Thanks!
by W5WLW on June 12, 2002 Mail this to a friend!
Enjoyed your article immensely.
73 de Eric, W5WLW
by AA3WS on June 12, 2002 Mail this to a friend!
Nice article. I like the tip on patience. I have little sometimes (most). Hi Hi
AA3WS
RE: Practical tips for home brewing
by AG4RQ on June 13, 2002 Mail this to a friend!
"So how exactly does one get into home brewing? The study guides don't cover much on this subject. Is The ARRL Handbook is a little too much for a raw beginner?
What are other pieces of required reading on the art of homebrewing?"
A good source is the TIS Pages on the ARRL site, which can be found at:
http://www.arrl.org/tis/tismenu.html
You can also do a Google search on "homebrew" and "homebrewing".
Homebrewing is not a skill that is acquired. It is gradually developed through the years.
Reading the author's article reminded me of myself. I have not discarded anything electronic since 1978. I wasn't even a ham back then, but I was into CB. I don't even throw away a small piece of wire. I may be able to use it for a jumper some day. I even save wire insulation scraps. These come in handy for insulating the leads of a resistor or a diode for projects. I have chassis from all kinds of electronic stuff that gave up the ghost throughout the years. Also, one of those parts cabinets with the plastic drawers is a must. I have one with 60 drawers, and it just isn't enough. The term "junkbox" is not an accurate description of most hams' electronic parts collection. My "Junkbox" is way too big for one lousy box. My "Junkbox" is all over the place - on shelves, in cartons, in the closet, etc.
A dedicated room with counters and cabinets, like the author's would be nice. My shack and most of my junkbox is in my bedroom. My "bench" is a small folding table which folds up and goes in the closet when I'm not doing any bench work. Such is the price you have to pay when you don't have the space. I live in a small one-bedroom apartment.
by N8AUC on June 13, 2002 Mail this to a friend!
If you search Google, make sure you include the
word Radio in your search, otherwise you'll end
up with a search that yields info on making beer
in your basement. It's odd, but it appears that
more people make beer in their basement than
radios. Go figure.
The links section right here on eham.net is a good
place to start.
Getting into "homebrew" is a gradual process...
kind of like the progression of a disease. Early
symptoms include removing power cords from deceased
household appliances before they hit the trash.
You never know when you'll need that cord for a
power supply project.
Then it will be old junked TV sets. The older tube
models are great for scrounging parts from. One of
the old 83 channel UHF tuners out of an old set
has many uses...especially if it's varactor tuned!
Old clock radios yield great cabinets for QRP rigs.
A dead "boom-box" can yield some nice IC audio amp
parts. But by now you get the idea. In advanced
stages of this condition, you will find yourself going
to hamfests to shop for parts - and ordering stuff
from places like Digikey, Mouser, and Dan's.
An elmer is extremely helpful. A copy of the ARRL
handbook is almost required. It's not light reading,
and if you have questions, ask someone. Also
recommended are books by Doug DeMaw(SK) - these were
also published by ARRL.
WARNING - Homebrew ham radio can be addicting - but
is not hazardous to your health! Just a lot of fun!
Now go melt solder!
73 de N8AUC
Eric
WARNING !!!!!!
by VK2GWK on June 13, 2002 Mail this to a friend!
N8AUC wrote:
"WARNING - Homebrew ham radio can be addicting - but
Now go melt solder!"
Although emotionally I can fully agree, the lawyer in me has to express a caveat....
Homebrewing can be hazardous when you work with "live" equipment connected to the mains grid or with high voltages! Be extremely careful with this sort of equipment. Make sure you have differential trip switches in the mains circuit and keep one hand in your pocket while working on HV stuff.
Now on the "melting solder bit"....
Recently (probably too late for me) I built a small ventilator under the magnifying glass I use for close up soldering to disperse the vapours that come off the soldering joint. Some of this stuff can be carcigenous. I have been breathing this stuff for most of my life, but still, better safe than sorry....
RE: WARNING !!!!!!
by N3JIY on June 14, 2002 Mail this to a friend!
You're so right. It does NOT work the first time.
I could have saved myself a lot of grief if I had
known that if you follow the directions exactly, and
make sure you assemble the circuit carefully, it still
will NOT work the first time. There is always a pro-
blem to be solved. That is how the learning takes place.
Nice article.
by W4XKE on June 14, 2002 Mail this to a friend!
Great article! I just bought a proto board with power supply and 2 boxes of wire leads & components at the "Radio Amateur Club of Knoxville (RACK)" hamfest. Now I'm anxious to try it out. I am presently enrolled in electronics technology at the local tech center and am looking for a used oscilloscope for my bench.
I am especially impressed with the photo of the perf board with all of the labels, identifying the components! How was this done? I have a digital camera and can create photos with MS Publisher, but it won't print the labels transparently across the photo. Instead, it cuts out a block of the photo for the text to be inserted. I'm sure others would like to know how to do this, so I thought I'd ask here where we could all benefit from the answer. Thanks for the great article. Respectfully, Johnny W4XKE (good in QRZed)
by AG4RQ on June 14, 2002 Mail this to a friend!
I just scrapped a computer monitor, which smoked and gave up the ghost some months ago. Its amazing what you'll find inside one of these. In addition to 2 large ferrite doughnuts, loads of wire and numerous screws, there were 3 PC boards full of parts - one large PC board and 2 small ones with loads of transistors, diodes, caps, resistors, chips, etc., not to mention the high-voltage transformer for the CRT. The only things I wound up throwing out were the cabinet and the CRT. Who knows, one of these days, I might regret discarding them!
by VK3JED on June 15, 2002 Mail this to a friend!
Excellent article with lots of good, practical tips. Homebrewing is one of the most satisfying parts of ham radio. There's nothing better than using some project you built yourself, whether that be a complete transceiver, or merely a PSK-31 PTT interface (yes, I built mine out of mostly 15 year old parts from the junk box :) ). I've built a number of small projects from mic preamps to simple control circuits, accessories and more, and that thrill of doing the "smoke test" and it finally working is still as big now as it was when I built my first FM wireless mic, some 20 years ago. :-)
by W5VPU on June 19, 2002 Mail this to a friend!
Hey, Henk!
You did a thoroughly magnificiently inspiring article on getting homebrewing started again.
You encouraged me. And I plan to show it to my ten-year-old grandson when he comes over tomorrow for a visit to "learn about radios some more." He spent a couple of hours talking on my Ten Tec Jupiter with some folks in Fort Worth from here in Oklahoma City last Sunday. His eyes just bugged out with this "new world."
Thanks, and g'day.
73, Raymond, W5VPU
by KG5BV on June 24, 2002 Mail this to a friend!
Ah, it's so good to hear from one of like mind! I was about to think there wasn't any of us home brew types left. I always like to ask the other ops if they have home brewed anything at their station. Most have, anything from a dipole to a complete solid-state HF transceiver (by an 18 year-old op, no less! There is hope for Amateur Radio!). But then there are those that really foul up my day with lame excuses like:
1. It's too expensive
2. It takes too much time
3. No one does that anymore
and my all time favorite...
4. I don't build stuff because it has no resale value
Ugh, he completely misses the point. An artist does not create because he expects it to bring profit (usually), he does it because it brings an inner joy. The same goes for home brew. Try it, you may like it!
If I may add a few bits of wisdom, they are:
The junk (treasure) will expand to fill the available space.
Don't throw it out today, lest you will have to buy a new one tomorrow.
If it works the first time, something is wrong.
Search for goodies in unthought of places, like scrap metal recyclers, yard sales, hospitals and universities. Ask to speak to the person tasked with electronic surplus disposal. You will be absolutely amazed at what normally gets dropped into a dumpster. You can amass large sums of treasure for free, or a small fee.
And most importantly, don't tell the XYL/OM/significant-other who gave you this advice! I have enough trouble explaining to my XYL what I am going to do with all of my junk! Home brew is good for you!
73, Dwight KG5BV
by N4DFP on June 30, 2002 Mail this to a friend!
Solid advice from someone who has it BAD! Wish I had the time to homebrew more. As an 18-wheeler driver, I get precious little time at home, and less free time on the road. The Radio Amateurs Handbook is never too complicated and I would also suggest Bill Orr's (W6SAI) Radio Handbook. If it isn't still in print, find a used copy (any edition) and never mind that it appears a little battered, you'll just batter it some more. Also look for good "Cook Books". These used to be pretty common and McGraw-Hill published a dandy. Don't sell the Electronics Book Club short either. Alas, one of the best homebrew resources is surely no longer in print -- The Boys First (Second, Third, and Fourth) Book of Electronics. This is the series that I went to after getting my first crystal radio kit nearly 40 years ago. There were wonderful simple projects even up to a 5 tube 40m transmitter in the fourth of the series. These were the books that assured that eventually I would become a Ham.
by RXSCRAM on July 1, 2002 Mail this to a friend!
The symptoms of my disease came on in just about the opposite order of what you described. First, I ended up ordering huge amounts of parts from RadioShack (big mistake, before I knew about the other places... such as...) ...DigiKey, as well as all the catalogues from Mouser and the other electronic retailers. After that, I ordered all sorts of junk from E-bay, including 5 different O-scopes (all in varying states of (dis)repair.,) and many, many boxes full of "junk" parts. After that, I started collecting old TV's, and other such stuff. Hmm... same disease, different symtoms, I guess!
by VE9CES on September 19, 2002 Mail this to a friend!
I was just going through some older articles here on eHam.net when I ran into this one. I must admit that I have only been licenced since 1999. A friend of mine, an older ham, has been "donating" (read cleaning out his basement) old radios and TV's to me for the last 6 months. I take them and strip them of the componants, and so build up my "junk box". I was very interested in the comment about using the heat gun. I've been doing it the hard way, ie desoldering idividual componants.
I am certainly going to continue "homebrewing" and building up my junk box. Just one question, what do you do with the old picture tube from old TV sets? I HATE throwing them in the dumpster! I am terrified of some unsuspecting fool dropping something on top and having flying glass everywhere!
73's de VE9CES
by VE7YJA on February 23, 2004 Mail this to a friend!
Hey, I thought I'd say hello to all of ya. I'm only 16, and I'm getting into homebrewing. So far I've made two regens: 1T4 Battery set (18VDC on plates). And a 12AT7 Dual triode regenerative (Regen on one triode, Audio on the other). I haven't got my licence - yet. But, I'm going to be taking the test soon, and my callsign will be as such, so long as nobody else gets it first.... My parts have been collected up over the past four years, starting with dissambled RadioShack kits, all the way up to old tube amps. I've even got some test equipment:
5" Cathode Ray DeVry Oscilloscope (Just got it)
Heathkit IM-11 VTVM
Triplett 630-PLK VOM
Eico High Current Power Supply (0-30VDC)
Homebrew Variac (NOS Ohmite, Assembled By: ME!)
I also have got a RF generator kit on the way. My Dad was a ham back in the old days (40s-50s), when a 1Kw rig was half a basement. If anyone has any comments or suggestions for a new guy, just drop me a line. Oh yeah; does anyone have any suggestions for an uber-simple soldering iron temp controller, other than switching in a 3A diode? Thanks.
Which Battery Should You Use?
What Antenna Restrictions?
