Spacecraft Probe to Listen for ARRL Field Day Signals:
from The ARRL Letter on June 15, 2017
The Enhanced Polar Outflow Probe (e-POP https://epop.phys.ucalgary.ca/) onboard the Canadian Cascade Smallsat and Ionospheric Polar Explorer (CASSIOPE http://www.asc-csa.gc.ca/eng/satellites/cassiope.asp) satellite will again support Amateur Radio citizen science http://hamsci.org/article/e-pop-spacecraft-participate-2017-arrl-field-day by participating in ARRL Field Day http://www.arrl.org/field-day 2017, June 24-25. The HamSCI http://hamsci.org/ citizen science initiative says that, from a radio science perspective, Field Day is an ideal time for e-POP to study the structure of Earth's ionosphere using participants' transmissions. HamSCI was started by ham scientists who study upper atmospheric and space physics.
One of e-POP's instruments is the Radio Receiver Instrument (RRI), a digital receiver with four 3-meter monopole antennas. Its scientific objective is to study natural and artificial radio emissions from 10 Hz to 18 MHz. The receiver's monopoles can be electronically configured into a crossed-dipole setup, and it has two data channels -- one for each dipole. Each channel is sampled at 62.5 kHz and passed through a 30-kHz bandpass.
During Field Day 2015, the receiver was activated for 2 minutes while e-POP was just north of Milwaukee, on a southeasterly heading. It was in a crossed-dipole configuration, with its two channels tuned to 3.525 and 7.525 MHz, respectively. A spectrogram http://hamsci.org/sites/default/files/article/file/20151103%20ePOP%20Field%20Day%20Updated.pdf that summarizes the results shows that not only were CW transmissions visible on the 40-meter channel (B), but they were only observed for about the first 30 seconds, even though the Reverse Beacon Network (RBN) showed that these stations transmitted throughout the experiment period. No signals were received on the 80-meter channel (A), and, at least theoretically, those signals should not have been able to penetrate the ionosphere and propagate to the receiver during the experiment.
The signals heard can be used to study HF propagation, and the advantage of using Amateur Radio transmissions is that call signs readily identify a signal's source, which can be fed into a HF ray trace model, and then used to elucidate the properties of the ionosphere during the experiment. During Field Day 2015, 23 call signs were identified.
One hypothesis under investigation is that the ham signals disappeared as the spacecraft headed south into latitudes where the ionosphere was denser and blocked the transmissions.
For Field Day 2017, e-POP will dedicate all of its resources to studying HF radio wave propagation using ham radio transmissions. The Radio Receiver Instrument rwill be tuned to the 40- and 80-meter CW bands, although precise frequencies have not yet been determined. It is scheduled to be activated six times, in 10-minute increments, over Field Day weekend. Read more http://www.arrl.org/news/spacecraft-probe-to-listen-for-arrl-field-day-signals.
New 23cm IARU Region 1 Record Claimed:
Spectrum Pollution and Intruders Put Urban Radio In Doubt:
Historic Flight Over the Pacific Ocean:
Intercepts and Ham Radio at the Top of the World:
New BCH-270 Handheld Radio Now Available:
