Propagation Forecast Bulletin #15 de K7RA:
from W1AW Bulletin via the ARRL on April 13, 2018
ZCZC AP15
Propagation Forecast Bulletin 15 ARLP015
>From Tad Cook, K7RA
Seattle, WA April 13, 2018
SB PROP ARL ARLP015
ARLP015 Propagation de K7RA
No sunspots were seen over the past reporting week, April 5-11, so average daily sunspot number declined from 3.3 to 0. Average daily solar flux declined from 68.6 to 67.7. Average daily planetary A index increased from 5 to 9.4, and average daily mid-latitude A index went from 4 to 8.1.
But on Thursday, April 12, a new sunspot appeared, AR2704, and it is a small one. However this one is three times the size of new sunspot groups appearing on March 30, March 17, March 15, and March 2.
Spaceweather.com reported:
"A minor G1-class geomagnetic storm is in progress on April 11th as Earth moves through a high speed stream of solar wind. This is causing bright auroras around the poles, with Northern Lights sighted as far south as the Dakotas in the USA. The gaseous material is flowing from a wide hole in the Sun's atmosphere--so wide that the stream could continue to influence our planet for the next two to three days.
"Visit Spaceweather.com for updates."
Predicted planetary A index is 15, 12, 8 and 5 on April 13-16, 8 on April 17-18, 12 on April 19, 15 on April 20-21, 12 and 10 on April 22-23, 5 on April 24 to May 5, 8 on May 6, 18 on May 7-8, 15 on May 9, 12 on May 10-11, 8 on May 12-13, 5 and 8 on May 14-15, 15 on May 16-18, 12 and 10 on May 19-20, and 5 on May 21-27.
Predicted solar flux is 70 on April 13-19, 69 on April 20, 67 on April 21-22, 68 on April 23 to May 5, 67 on May 6-19, and 68 on May 20-27.
Interesting article about the next solar minimum:
https://bit.ly/2HkdjsP
I do not know if this claim about the biggest sunspot is accurate or not: https://cbsn.ws/2GTZNNi .
Another interesting article. Note there seems to be no correlation between geomagnetic storms and troubled whale navigation:
https://bit.ly/2IQ4MLf
Geomagnetic activity forecast for the period April 13 to May 8, 2018 from F.K. Janda, OK1HH.
"Geomagnetic field will be:
Quiet on April 24-25, 28
Mostly quiet on April 23, 26, May 4
Quiet to unsettled on April 17-18, 27, 29-30, May 1, 3, 5, 9
Quiet to active on April 13, 15-16, 19, May 2, 6, 8
Active to disturbed on April 14, (20-21,) May 7
"Solar wind will intensify on April (24-25,) May 5-7, (8)
"Remark:
- Parenthesis means lower probability of activity enhancement.
- With regard to ongoing changes, current forecasts are less reliable again.
- Beware of paraskavedekatriafobia!"
Dr. Tamitha Skov wrote:
"We are enjoying a mild solar storm due to some fast solar wind from a large coronal hole that will be gracing much of the Sun's face over the next few days. The strongest part of this storm has already hit, bringing aurora down to mid-latitudes. Although the back half of this coronal hole is not as well formed as the front half, we should continue to see pockets of fast solar wind causing sporadic boosts in activity through the weekend. Amateur radio operators might take advantage of auroral propagation modes, since the solar flux remains low with our near-solar-minimum Sun.
"Speaking of, talk of the approaching solar minimum has been hot and heavy as of late, even in scientific circles. We have seen a faster drop towards solar minimum than many expected. This bolsters my hopes that we are indeed crossing through the solar minimum phase more rapidly than predicted. In fact, some recent analyses are indicating we might reach solar minimum as early as sometime this year!
"As if on cue, the Sun gives us a glimpse into the future this week by birthing a sunspot with a signature that confirms it belongs to the upcoming solar cycle. These new-cycle regions are perfectly normal and will become more common as time goes on. They also serve as comforting reminders that the Sun is not diving into a new Maunder minimum (with no sunspots for 70 years), nor is it plunging us into another ice age. These regions are heralding the coming of a new cycle. So rest easy. Sunspots will return and likely sooner than most people think."
https://www.youtube.com/watch?v=yNccIuI5HUwfeature=youtu.be
Note that Dr. Skov said a new spot has a polarity suggesting it is from the next solar cycle, which is Cycle 25.
Sunspot numbers for April 5 through 11, 2018 were 0, 0, 0, 0, 0, 0, and 0, with a mean of 0. 10.7 cm flux was 66.4, 67.3, 66.8, 67.9, 68.7, 68.5, and 68.3, with a mean of 67.7. Estimated planetary A indices were 9, 4, 5, 5, 11, 18, and 14, with a mean of 9.4. Estimated mid-latitude A indices were 8, 3, 4, 5, 11, 14, and 12, with a mean of 8.1.
by W7TJ on April 14, 2018 Mail this to a friend!
The Forecasters missed predictions on the current cycle ( 24 ) by a country mile....they were not even close. Until we have reverse polarity sunspots at High Latitudes on the sun, and sunspots grow substantially in magnetic size, strength, and complexity - all this wishful thinking is a pipe dream.
Caister Calling... Radio Hams Enjoy International Marconi Day:
P.E.I. Ham Radio Operators Celebrate Marconi Day in International Event:
Binghamton Amateur Radio Association Celebrates Marconi Day:
Amateur Radio Enthusiasts Celebrate Marconi Day at Museum:
Phone from Home: Salado Students Call Astronaut:
