Build Your Own Air Variable Capacitors!
David F Hammack (N4DFP)
on
April 29, 2003
Website:
http://www.qsl.net/n4dfp/buildcaps.html
Build Your
Own Transmitting Air Variable Capacitors!
By: David
Hammack, N4DFP
| As I was
building my transmatch, I became increasingly
dissatisfied with my choice of capacitors. They were too
small for more than about a hundred watts, and the ganged
capacitor was in pretty sad shape. The frame was rusted
and I could not remove all of the oxidation from the
plates. I had a very nice Hammerlund 450pf that would do
well for the Input Tuning, but I didn't have an
equivalent ganged capacitor to use for Output Tuning. I
am temporarily disabled and have no income at the moment,
so it looked as if my transmatch would either be
constructed of inferior parts or put on hold
indefinitely. As I was looking over the Web, I came
across an article by DL5DBM, Anwar
von Sroka
on building your own capacitors. It looked pretty simple,
but I was concerned that the materials would strain my
very limited budget. I did some thinking and looked
around my local hardware store to check the price of
materials. I found that the heavier gauge sheet metal was
beyond my price range, but a 10' roll of aluminum roof
flashing was only about $4.00. I figured I could manage
that, so I looked for the other materials. A 3' stick of
1/4" all-thread was only $0.99. I couldn't find the
spacers, and did not have a tubing cutter to make them
with. I knew from experimentation that the spacing on the
Hammerlund Capacitor's plates was the same as a 1/4"
nut, so I decided to use nuts as spacers. I didn't feel
the flashing would be suitable to make the contact spring
for the rotor, so I found a small compression spring to
use for tensioning the rotor to the contact plate. I also
decided to use nylon filled stop nuts for securing and
adjusting the rotor. The total bill of materials came to
less than $15.00, and all materials were found at my
local hardware store. I had some Lexan on hand to use for
endplates, but any good non-conductive material such as
PlexiGlass, Teflon, Nylon, Lucite, or phenolic would
work. Usable scraps are usually available at reasonable
prices at most glass shops or plastics suppliers. I would
recommend not less than 1/4" thickness. Construction
Rather than use Anwar's measurements,
I modeled my capacitor on the Hammerlund. Since it was
25 plates on the rotor and 24 plates on the stator,
rated at 450pf, I figured that 12 rotor and 12 stator
plates would give me something on the order of 220pf.
I measured the Hamerlund as illustrated:
This layout was
drawn with Cadvance 6.5b, a free program available at www.cadvance.com
 One major advantage to using
flashing is the ease with which you can work it. It can
be easlily cut with a good pair of utilty scissors. Do
NOT use your XYL's favorite dress shears for this!
When making your plates, lay out one of
each, cut them out, and then use them as templates to
layout the rest. Here are the plates, all cut out.
Since no one is perfect, make sure you mark an index
on each plate as you cut it out. This will insure
proper alignment when you assemble the device.
Drill the endplates. It is a good idea to
drill both together so the holes will match front and
back. To make the contact plate for the rotor, cut a
strip of flashing long enough to cover the rotor shaft
hole on both sides. After bending the strip over the
endplate, drill a small hole to accommodate a 1" 6-32
brass screw.
Next, drill the shaft holes in the rotor
plates. Again, in order to insure the uniformity of
the parts, you should drill all the holes at once. I
used scrap Lexan to hold the plates in the jaws of a
Vice-Grip. Dimple the top plate of the stack at the
center of the hole. It is a good idea to drill a small
pilot hole before drilling the 1/4" hole.
Now, take a rotor plate and a stator plate
and tape them together in full mesh. Make sure the
shaft tab on the rotor plate is properly aligned with
the cut out in the stator plate.
Align the shaft hole in the endplate with
the shaft hole in the rotor plate and square the
endplate over the parts to be marked. I used a carbide
tip scribe for marking, but any sharp pointed object
could be used. In a pinch, you could use the point on
your pencil compass for marking.
Separate the rotor and stator plates you
just marked. Stack all of the stator plates together
insuring that the rotor tab cutout matches and tape
them. This will keep them from slipping when you clamp
them for drilling.
Cut the all-thread for the stator rails.
For a 220pf capacitor of 12 plates, 4-1/2" is
adequate. Mount these in the back end plate, leaving
3/8" to 1/2" beyond the outside nut. Secure them to
the inside using 2 nuts per rail to leave adequate
space for the rotor.
Begin mounting the stator plates. First
flatten them as much as possible, removing the bows,
twists, and curls. Make sure they are properly
aligned. This is where the index marks you put on the
plates come in handy.
As you mount the plates, tighten the nuts
finger tight - do NOT use a wrench. Excess torque will
deform the plates, making alignment extremely
difficult. Look for a bowing in the plate. Either the
plate was not flat, or the nuts are too tight. Correct
this now before proceeding to the next plate.
Once the stator is assembled, assemble the
rotor, again flattening the plates as much as
possible. The shaft should be cut an 1-1/2" to 2"
longer than the stator rails. Use a stop nut as the
last nut in the rotor assembly,and then a regular nut.
This will hold the regular nut allowing
you to torque the first plate into position, and will
later be used to adjust the turn tension. Assembly of
the rotor will require a wrench. As illustrated, use
some kind of spacer to tighten the plates against.
This will insure that the plates remain level and
allow you to torque the nuts fairly tightly.
Now you are ready for final assembly. Hold
the completed rotor in a full unmesh position and
insert the shaft into the back endplate using 2 Teflon
or Nylon washers on either side of the plate at the
rotor shaft. You may need to add a washer to each side
of the stator to allow space. Secure the rotor with a
stop nut . Rotate the rotor to full mesh and install
the front plate. Secure the plate with regular nuts on
the stator. Place a flat washer, the compression
spring, and another flat washer on the rotor shaft.
Secure these with a stop nut. Tighten the stop nut
till the spring compresses, tensioning the rotor
shaft. Now tighten the stop nut on the other end of
the rotor to center the rotor plates in the stator.
Judge proper centering at the shaft.
It is possible that you find the rotor
turns too freely to suit you. You can adjust turns
tension by tightening the inside stop nut on the rotor
shaft against the backplate to provide a more pleasing
tension. Likely, you will need to adjust the rotor
plates. This is accomplished using a small screwdriver
to slightly bend the plates at the shaft. Be gentle, a
little at the shaft translates to a large movement at
the outer radius. If you have developed a slight bow
in a stator plate, use the screwdriver in the same
manner at the nuts on the stator rail. Only as a last
resort should you attempt to adjust the capacitor with
needle nosed pliers.
Now your capacitor is complete and ready
for your project!
Conclusion
As I assmbled this unit, I came to the conclusion that
Anwar's use of spacers, rather than nuts is probably a
good idea. If I were using spacers, I would use a stop
nut on either end of the assembly to prevent
loosening. Flashing is not the best material to use.
If you can find it easily, I would recommend a heavier
gauge material. Anwar made a very valid point of which
I was not aware when he critiqued my design, which I
will pass on here. Sharp corners should be radiused to
prevent arc over. It would be a simple matter to round
of the corners with a mill file as you drill the
holes. I suspect if I use significant power, I will
probably have to rebuild the capacitor with radiused
corners after it arcs over.
Transmitting air variables are becoming scarce and
expensive, even at Hamfests, and the kit capacitor
from TenTec is over $50.00. This is a viable
alternative for medium power projects. Though I have
not tested it, I suspect a carefully aligned capacitor
of this type would easily carry a kilowatt. This would
be perfect for a Transmatch or the coupling capacitor
in a Loop Antenna without breaking the bank. Ham Radio
is a fun hobby, but it doesn't necessarilly have to be
expensive, as long as you carry on the HomeBrew
tradition!
I would like
to thank Anwar von Sroka, whose excellant article inspired
this project.
A small little program to calculate capacitor
parameters (along with many other GREAT design
programs) can be found at:
http://www.qsl.net/ve3sqb/
Make sure you
look at my Transmatch Project in which I used a homebrewed double
ganged capacitor.
by N4DFP on April 8, 2003
Mail this to a friend!
One point I forgot to make in the article: When making your plates, lay out one of each and cut them out, then use them as templates to make the rest.
by K1VV on April 29, 2003
This is REAL HAM RADIO !!!
Whitey K1VV
by VK4JAM on April 29, 2003
This articale is brilliant !
Not sure that I agee with "Do NOT use your XYL's favorite dress shears for this!" .... it suspect the successful use of this type of shears will depend on several key factors: (1)how fast you can run, and (2) how well you have planned your getaway ! :-)
Thank you for a great article.
Andrew
VK4JAM
RE: Build Your Own Air Variable Capacitors!
by N0UY on April 29, 2003
Nice Article David.
Like every project, when it's done you can always find something you'd like to do differently. I find that to be true at my job also. As far as using the XYL's shears for the project, I would consider it as fair payback for all the times my tools were used to stir paint, chip ice, or serve as temporary markers in the vegetable garden. But seriously, good materials are the core of any successful project. Hope you enjoyed the effort, it's the most important part.
73, Ray N0UY
by K8AG on April 29, 2003
Fantastic article. I will bookmark this and reference it.
John Pawlicki, K8AG
by WB4ONA on April 29, 2003
Nice Article, some comments and questions:
Stack up the plates and use a drill then hole-saw. Cut the stack in half and solder/braze the plates to the shaft. Maybe a way to offer these hard to find caps to the Ham community if someone wanted to produce them. (Those machining excellent hand keys and bugs for us may take note; a new market for you?)
A good place to get specifications on and order stock materials is McMaster-Carr, http://www.mcmaster.com/ I haven't ordered from them for years, but they are alive and well. Good site for for metal sheet, teflon/insulators, mechanical goodies like bearings etc., all kinds of stuff. Plenty of specifications too on their Web site. (I have no relation with McMaster-Carr).
Perhaps a Lost-Art? "Linearizing" air-and dielectric spaced variable caps: Does someone have the equations to cut the plates on an air-variable to make "cardiod" plates that "band-spread" the tuned filters they are a part of so tuning is linear (or otherwise) in terms of shaft rotation? Remember the old 365pf "front-end" tuner caps in old tube AM receivers? They did this and I suspect there's a legacy of information on how they were designed that may be lost.
73's, Dave
by K3AN on April 29, 2003
Great info. We need more how-to articles like this.
If anyone can direct me to information on home-brewing a set of tires for my car, I'd appreciate it. I'd even settle for learning how to do retreads. ;-)
by WR8Y on April 29, 2003
Two great articles in a row? I hope this trend continues.
Mark
WR8Y
by N8FVJ on April 29, 2003
Refreshing article. Removes that 'buy it now, pay later' mentality & reinforces the Amateur Radio self-sufficiency some of us now keep in our back pocket (not the wallet side folks).
by AB5Q on April 29, 2003
Very creative, thanks for sharing your capacitor project with us.
by KB9ERU on April 29, 2003
GREAT job on the project.
Thanks for sharing with the rest of us!
This is INDEED REAL HAM RADIO!!!
...now where are those scissors....hihi
by WN9V on April 30, 2003
That's a great article, using common hardware store goods to build an otherwise hard to find component.
The base design, could be expanded into multi gang capacitors, differential capacitors, and, with some modified stators, even butterfly capacitors. Who will be the first to use all home made caps in a copy of the Johnson Matchbox?
Here are a couple of suggestions for refinements:
Whether the plates are made of thick or thin stock, I would recommend smoothing the plate edges and corners using wet and dry sandpaper of approximately 200 to 300 grit then finishing with 400 or finer grit. If you do this sanding while keeping the work wet with water, the sanding will go quickly. The rounded off edges will help avoid arcing.
Some capacitor applications involve significant circulating currents. The Z match is one. For simplicity and a reliable low-loss connection I suggest using a short, solidly connected jumper instead of the sliding rotor contact. Assuming the capacitor is limited to turning only 180 degrees, an inch-long jumper made of braid or finely stranded wire would last a long time. One end of the jumper would be soldered into a hole drilled in the center of the back end of the capacitor shaft. The jumper would extend straight out the back of the shaft and be secured to an insulated tie point which would then serve as the rotor terminal. Use a heat sink when soldering the stranded jumper so that the part that needs to twist does not wick up the molten solder.
I hope the article by David N4DFP inspires others to present more hands-on projects that are easy on the budget and don't require a machine shop to build.
by AG5P on April 30, 2003
Great article, David. Thanks for the ideas
and extra URLs. Very well done!
Just a note, if you are building air caps for
VFO tuning or just need a small air cap, the
brass washers cut in half make nice plates,
just use tiny brass split ring washers for
the spacing and aircraft nuts on each end
of the all-thread rods. Like David, mentioned
be sure to smooth all sharp edges on the plates.
For tension to avoid free turning you can use
several nylon washers between the first rotor
plate and the front housing to snug up the
assembly and use a small amount of teflon
spray lubricant for smooth turning.
My preference is to make split-stator air
caps and get away from the electrical contact
problems of the standard air cap.
Walter - AG5P
by K0TRL on April 30, 2003
What a great article. It is refreshing to see someone build something useful from scratch today and then share how to do it with everyone! This capacitor even looks great. Maybe this the the 21st century internet Elmer. I hope so.
by W8OB on April 30, 2003
Super article this is just what ham radio should be like again. The author of this can say he is really homebrewing a project
by N3NYC on April 30, 2003
Dave, WB4ONA,
There's a section on how to design a capacitor for straight-line-frequency operation in "Principles of Radio Communication" by J.H. Morecroft (John Wiley and Sons, 1921, 1927). The book needs a bit of interpretation, sometimes, due to the use of obsolete units, but it's a gold mine of old, half-forgotten stuff.
Hale, N3NYC
by KE4ZHN on May 1, 2003
Excellent article Dave! This is what ham radio is all about! Very few hams these days homebrew anything due to the ease at which one can buy about anything you can imagine. Its great to see people like yourself still keeping alive the true spirit of ham radio by homebrewing your own air variables. Keep up the good work.
by WA8QNN on May 3, 2003
Great article Dave! This takes back to my amatuer radio beginnings, when ops made their own equipment, antennas and modifications.
Larry
by VK3BSF on May 11, 2003
What a great project!! I built a switched inductor for L1 as rotary inductors are also impossible to buy. Maybe someone can come up with a homebrew design using the same philosophy that David used. http://w1.859.telia.com/~u85920178/ under antenna projects..tuners..describes how to build a switched inductor instead of using the roller type. I can recommend this design as I built one for my tuner and works well.
by KD5INM on September 7, 2004
I've found that Dollar General Stores carry a cheap cutting board made out of some tough white plastic. This material is probly a type of nylon and is hard against knife cuts, but can be sawed into squares or whatever shape and would make good end pieces, probly much more resistant to heat like that is generated in amplifiers and such than what maybe lexan or plexiglass.
This is an excellent article, I enjoyed reading it.
73' John Hamilton KD5INM
by LOWTECHLOU on September 28, 2004
I have been looking for plans on this subject for a while. I want to build a bigger set and see how the dx-ing comes through? ill let you know...
lowtechlou
by AP2WF on December 14, 2004
I am a Home Constructor myself and was very much facinated with the idea and available drawing tool on the web site. The availability of these mechanical electronic components like Gang Capacitors is a problem here. So I am inspired with the idea and want to thank the writer of the Article.
by GEOCORONA on February 23, 2005
I've been playing with variations of this project for the past two weeks. Some things I've learned:
* Aluminum flashing has "memory"-- it wants to stay curled in the direction it was rolled. Lay out your pieces so they curl across the shortest dimension, and keep the same side of all pieces facing the same direction to reduce warp & rubbing.
* Using cylindrical spacers (such as washers) instead of nuts doesn't help the rotors grip the axle. They often fan out as the axle is turned, even when rough-sanded for texture. Since aluminum doesn't solder with normal resin-fluxed tin, creating a sturdy electrical & physical contact to the axle can be tricky.
* Drill bits tend to grab and torque sheet metal. Soft steel (like that used in cookie tins) is worse than aluminum for this, but at least it solders.
* Using 10 mil Lexan as a dielectric insulator (4.4 dielectric constant) helps to drastically reduce the size of the capacitor, but I suppose the wattage rating is going down drastically, too.
If I ever get a successful capactor, I'll let you know.
by GEOCORONA on February 25, 2005
Okay, I think I have it solved. When using spacers instead of nuts to hold the rotors, I drilled two tiny holes near the 1/4 inch axle hole of the rotors, and ran a piece of copper wire bent like a long staple through the holes. After the last rotor, I bent the two wire ends together and soldered them.
Now if one rotor grabs, they all grab.
Also, a droplet of superglue on the assembled axle where extra "stick" is required doesn't hurt (surface only -- not for joining metals). Nor does a little wipe of WD-40 on the rotors when using plastic film instead of air space.
No more AM air RX on 2M mobiles?
The 'Mouse-Keyer':
Homebrew Your Own Separation Kit (857D)
My New 6L6 Transmitter
An X-O Polarimeter
What Antenna Restrictions?
Multi Amplifier Keying Buffer
