73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Riversink Elementary Students Will Contact Astronauts:
DX News -- ARRL DX Bulletin #4:
Just Ahead In Radiosport:
ARES, SKYWARN Volunteers Go On Alert for Massive East Coast Winter Storm:
FCC Paperless Amateur Radio License Policy Goes Into Effect on February 17:
