73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Ham Radio Operators Pass Wet Weather Test:
Ham Radio Operators Make Air Waves Sizzle:
The Original Social Media: Group Broadcasts the Popularity of Amateur Radio
Wicker Pushing Fair Regulation of Amateur Radio Operators Measure:
Ham Radio Deluxe Expands Staff:
