73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Twisp Police Chief Ready to Train Citizens for Emergency Response Team:
Propagation Forecast Bulletin #51 de K7RA:
Can You Hear Me Now?
See a Stunning Solar Flare Captured By NASA:
