73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
New WIA President Announced:
CLASP Aids in Exploration of Sun's Outer Atmosphere's Magnetic Field:
Vintage Radio and Communications Museum:
DX News -- ARRL DX Bulletin #21:
Just Ahead In Radiosport:
