73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Elmhurst Amateur Radio Operators Celebrate Club’s 80th Anniversary:
Why Is Ham Radio So Important?
Ham Talk Live #33 -- Bouvet Island DXpedition:
Radio Club Offers Incentive To Residents To Become Licensed Operators:
Review of the Australian Radiofrequency Spectrum Plan:
