73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Amateur Radio Test In Bend:
