73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
DX News -- ARRL DX Bulletin #33:
Just Ahead In Radiosport:
Solar Eclipse QSO Party will Facilitate Real Science:
Amateur Radio Communication Resources to be Available During Eclipse Day:
Amateur Radio Administration Course (ARAC) Presented In Mexico for 2nd Year
