73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Radio Transponder Will Accompany Japanese Asteroid Mission into Deep Space:
73 on 73 Award Period Now Underway:
