73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
New Amateur Radio Parity Act Bill Introduced in US House of Representatives
RadFxSat (Fox-1B) Launch Moved to Late August:
Ham Radio Operators Spread the Word About Battle of Vimy Ridge:
Property Owner Wants to Remove Ham Radio Towers from atop Islandia Hotel:
