here's a map that shows the deviation
73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
If you want to calculate the current magnetic declination at your location, you can go to and use their magnetic declination calculator.
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
