73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Petaluman Shares Love of Skies, Safety:
Sun Blasts Out 2016's Strongest Flare (Video):
Ham Talk Live #24 -- Log Analysis NV9L:
Everything Ham Radio Podcast -- Mobile Radios:
St Albans Student Brought Down to Earth for Meeting with Astronaut Tim Peak
