73 de K6TE Wim.
was a LT :-)
73 de Ronnie
Have fun and 73,
Does GPS know the difference?
You are confusing your terms.
Oh, you're not on a boat?
RE: Oh, you're not on a boat?
Ham Radio Coming to PCHS:
Ham Radio Operators Assist With Puerto Rico Recovery:
